My washing machine (dwd-wd32ws) washes using hot water even though I set it on the cold water option.At first I thought that it uses cold water, then hot water at the end, but that is not the case.
It's uses only hot water. Why? Is it broken?
try and switch your hot and cold water hoses around the other way. it should start the cycle with hot and rinse cold.. If it still does it you may have to have it serviced..
jm
The problem is that it only uses hot water. But I would like it to be all cold water. Is there any way to do that?
(Thank you for your reply)
