Was the replacement lamp the same part number as the original as there are different arc gaps for different lamps and the wrong arc gap will cause the lamp not to light. Since the ballast is powering up the lamp should light if the baalast is matched to the correct arc gap of the lamp being used.
Here is the diagnostic flow chart for your model which should pinpoint where the problem is at
Sorry you cant see the flow chart due to the size. Send me a email at [email protected] and I will send the info via email to you.
The company I work for has one in stock. www.tvrepairworld.com you can send them a email or call
Yes it was same part #.
More info on problem - tv worked great until we turned it off, then would not turn on next day. A couple weeks before it went out, it didn't turn on one morning for an hour or so, then tried again & came right on.
Email to [email protected]
Looks like I need a DMD board part # BP94-02217A and can't find one with internet search. Samsung parts says no longer available.
Any suggestions?
