Question about Belkin Computers & Internet
Help wireless usb adapter connected to my computer but will not connect to the internet. i have got a wireless broadband box with sky it would be great if you could help me many thanks
  • 2,277 Answers
You are trying to conenct to the network.
When you try to connect to the network, do you the network in the list ?
If not then check the settings of the router.
I think you know all the wireless settings of the router .
If not then you will need to check the wireless settings of the router.
Click Here for step by step solutions
Posted on Nov 29, 2009
  • Belkin Master
  • 32,281 Answers
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router
Posted on Nov 28, 2009
When i unplug the cable from my computer i loose internet connection
Unless your computer also has an active & configured wireless adapter, then disconnecting the Ethernet cable between the computer and the router _will_ cause a loss of Internet connectivity.
Jan 10, 2011 | Belkin Basic Wireless Router
Acer5536 laptop will not connect to the internet wireless will connect by ethernet cable why
you might have a modem with an ethernet connection to connect to the net .
if you have a laptop you can choose a wireless usb broadband modem which can work on a desktop also once you recieve the modem just insert the modem into a usb port and follow the prompts you might need some drivers for the usb broadband modem which can be supplied by the ISP internet provider
hope this helps
Nov 14, 2010 | Acer 91.AB370.001 Network Adapter
How can i connect my desktop computer to the internet plz i need someone to help
Currently, the most common way to connect a desktop system to the internet, is by using the network jack to connect to a broadband cable modem or DSL modem. To do either you must have the service from either you cable provider or phone company (For DSL) and have the modem device for the service. Fees run $20 to $50 a month depending on speed you subscribe.
You connect the device to the system using a CAT5 network cable to a RJ45 (8 wire telephone type jack). Some Cable/DSL modems also have USB connection capability for the few systems these days that do not have a built in RJ45 connector To use them, you install the associated software, then connect the USB cable when prompted.
If you don't have Cable/DSL then dial up telephone modem is the next option, this requires a telephone modem that has an RJ11c telephone cord jack connection, most current computers only have a telephone modem as an option, but they can still be bought for around $20 and you will require a dial up internet service (Few remain, one is Netzero in the USA)
Mar 11, 2010 | Computers & Internet
I have Sky Broadband withe netgear router. Bought a netgear wireless adapter to use with my Advent PC. Installed everything. Good connection, but won't connect to internet. Keeps flicking from connected to...
HI,
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as sky (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
scan for the wireless network on the computer with the adapter and connect to the network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Aug 03, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Having problem in wireless sky broadband and desktop pc
hi,
tele you router show concocted internet if yes,
cheek your cable
and the common thing abut your system what this show in the network concoctions is there Local Area Connection concted show you sent received bytes
R
cheek your router configure for internet
Dec 13, 2008 | Computers & Internet
I would like to know how i can set up my computer to go wireless, i am already connected to sky broadband and have a wireless router, but i have to keep connecting the yellow cable to my laptop to get onto...
I would suggest a usb wireless adapter. These are getting less expensive and not as confining as pcmcia network cards.
link
You could look for these at wal-mart sams'club best buy circuit city staples, etc
Apr 07, 2008 | Computers & Internet
How do i configure my Belkin router to work with Sky broadband?
I'm not into hacking what I cannot find on ISP's sites
From what I can gather from the Sky Broadband site reading the manual installation procedures -- the process is pretty much automatic when it comes to installing their equipment leaving no clues as to how they configure it. What is the model if the Belkin router? Options probably exist to attach your device to theirs either as a router (establishing a second network behind theirs) or an access point joining as a member of their network - meaning there would would be two wireless networks in either case in the house (as there are no indications I have found on the site that the provided the sky router can be configured in any way such as turning off wireless). At least according to the documentation the sky router's wireless is running WPA-PSK security / encryption which is good -- and the documentation for attaching non-sky wireless adapters appears to be documented here.
Sky Setup
Dec 15, 2007 | Computers & Internet
Belkin wireless G desktop network card
What has happened is that the proxy server on your last internet connection is in need of being redetected. you will need to delete any old cookies and internet files, also check in the internet explorer tools>internet options>connection, that the the the last provider you used is trying to connect instead of sky, so either select never dial a connection or sky as your default connection. Also check that in the properties of the belkin adapter that obtain an ip address automatically is checked in the TCP/IP properties. You may also need to refresh your browser a few times before you get on the net. A good temp file and reg cleaner, is Ccleaner, it's free and available at the link below http://filehippo.com/download_ccleaner/
Sep 10, 2007 | Belkin F8T003 Bluetooth (F8T003V) Wireless...
Computers & Internet Logo
164 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
