Question about GE Profile Spectra JGBP90 Gas Kitchen Range
My stove keeps beeping and the clock comes up with F1. what does that mean? It is electic prestige series self cleaning
Posted by customd19 on
Michael Masters
  • 6,784 Answers
Hi, This Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
Posted on Nov 27, 2009
Anonymous
    New Friend:
  • 8 Answers
F1 means Control Failure. Correction says Loss of element relay redundant driver protection. Not sure what it means but have the failure code right here since my oven just had FO and we have to replace the control panel which we cant get until Jan. GRR
Posted on Dec 10, 2009
I have Model #JER8750AAB Serial#16776012WK When uising the self cleaning feature, oven stopped and F1 displayed on stove ??
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Dec 19, 2010 | Jenn-Air Microwave Ovens
It displays F1 . Is this a fuse problem and where is the F1 fuse
HELLO THERE
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Feb 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
F1 error code, beeping
  • Disconnect power to stove
  • Gain access to the back of the clock (electronic range control or ERC).
  • Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  • Make sure everything is clear and will not short out when power is turned back on.
  • Turn power back on to stove.
  • Watch for the F1 and listen for the beep.
  • If you get the F1 and beep, replace the ERC.
  • If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    N
  • OTE: Some models incorporate the touch pad and the clock as one part.
  • Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Aug 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
    Hi
    F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
    8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
    thank u
    rate me!!!
    Aug 14, 2009 | Maytag Ovens
    What does error code f 1 mean on an electic range if i hit clear the beeping stops but comes back on in a few seconds
    Copied from another website:
    I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
    Jul 26, 2009 | Frigidaire Gallery GLGF389GS Kitchen Range
    F1 message on Maytag range
    This is what the code means.
    F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC)
    Good Luck and Please Rate
    Jan 08, 2009 | Kitchen Ranges
    "F1" error code on Magic Chef gas range Model 3488XRA
    the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
    Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
    Error code F1
    Error code F1 is for a defective touch pad or membrane (usually the touch pad). In this case you will need replace touch pad or membrane. It seems that water entered the touch pad during the self cleaning process, remove the touch pad and try to dry it. Good luck !!
    Jun 08, 2006 | Maytag MER5530 Electric Kitchen Range
    GE Profile Spectra JGBP90 Gas Kitchen Range Logo
    465 people viewed this question
    Top Kitchen Ranges Experts
    Ismael Rodriguez...
    Marvin
    Marvin
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
