Sharper Image Ionic Breeze 3.0 Air Purifier Logo
Question about Sharper Image Ionic Breeze 3.0 Air Purifier
I have the Ionic Breeze Hybrid GP from Sharper Image. It has an "arching" problem in the lower section of the grid. Can this be fixed? How? The unit goes into "drying" mode and the fans still run, but I don't think it does the ionizing.
Posted by davidenglebe on
Anonymous
    New Friend:
    Problem Solver:
  • 6 Answers
Had the same problem, sparking in the lower section. i cleaned the grid blades on the filter with a scotch brite pad thoroughly in the area that was sparking and cleaned the corona wires inside the back of the unit gently by rubbing with light grade sandpaper. the unit runs like new. give it a try.
Posted on Aug 03, 2010
  • Caron Wolff
    Caron Wolff Apr 26, 2015
    DO NOT, IREPEAT, DO NOT DO WHAT THIS UNINFORMED POOR EXCUSE OF A HUMAN BEING SAYS TO DO. OBVIOUSLY THIS IS A PLOY TO GET YOU TO ACTUALLY RUIN YOUR IONIZER. SCOTCH BRITE AND SANDPAPER REALLY?!?
1helpful
I have a Sharper Image GP Hybrid model 1724. I cleaned the pull out blades and the inside of the unit. When I turn it on, the needs attention light comes on almost immediately. How can I get the machine...
i found a solution to the sparking problem in the ionic breeze. purchased scotch brite cleaning pads from home depot. using a long strip of pad scrub the plates back and forth especially in the areas that seem to be emitting sparks. i did this and the unit runs quiet as a whisper.
Popping sound
SOUNDS LIKE THE ELEMENTS ARE DIRTY. FOLLOW THE DIRECTIONS IN YOUR OWNERS MANUAL TO CLEAN THEM.
1helpful
Ionic Breeze Hybrid GP air purifier only 1/2 grid gets dirty.
I have been doing research on this unit. I read that only every other grill is suppose to collect. The remaining grills increase the electrostatic charge making the collection plates, the ones that get dirty more effective. So the bottom line is there is nothing wrong with your unit.
2helpful
Sharper Image Hybrid GP Germicidal Air Purifier SI724 NO POWER
Oh there are a lot of known issues! I used to work for sharper image and I believed in this items very much so until mine broke. However after a year I figured out how to fix it. Take the big square collection grid out and the back screen off. Now get you a thick rag and be very careful because there are several tiny wires going up and down. Smaller than dental floss, you need to be very careful because you can either brake them or slice your finger wide open( Under any circumstances I can not be held liable for the information I am giving you try this at your own risk). Now with the towel very gently go up and down each wire like you are polishing a brass pole(once again these wires are thin and can break or cut you). Do this from the back side of the unit and from the inside where the collection grid that you took out sits. Take your time and be thorough, and presto your 400 dollar air cleaner is working again.
2answers
SHAPER IMAGE OUT OF BUSINESS
Sharper Image has recalled all Ionic Breeze Ionizers. This is what put Sharper Image into chapter 11.
For information see the link
See the EPA link as well
GP Professional Series Ionic Breeze - Simply Quit Working
Sharper Image models are no longer supported because they have been recalled since they were proven to be ineffective.
Here is a link about the Chapter 11
Here is a link for the EPA about ionizers
Ionic breeze gp grid
This is where you go to get what you need......
Hope this helps....good luck and thanks for rating my effort....the Fang.
S1730 sharper image ionic breeze GP
So you need another bulb correct
To order replacement lamps directly from The Sharper Image,
call 1-800-344-5555 and order item number SI922.
Lamps are effective for about 12 months of continuous use.
1helpful
4answers
Ionic breeze is arcing inside unit
I have a sharper image ionic breeze hybrid gp that ran fine for years unitl it recently started sparking / arcing at the base of the grid blades and always in the same spot. I cleaned it several times but the sparking always came back and the unit went into either "drying grid" or "attention required" mode. The solution I found was to stand the removable grid in 2 inches of Pine-Sol cleaner 50/50 diluted with water for 24 hours then brush again with the cleaning brush and hot water. Presto! No more sparking.
Top Sharper Image Air Purifiers Experts
Marvin
Marvin
David Shaub
Colin Stickland
Colin Stickland
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
