Question about D-Link (DI-784) Wireless Router
I have a dlink wbr-2310. My wireless works, but only after a fashion: it seems like whenever I want to use the wireless connection, I have to connect to the router console and simply go to the wireless settings and save them again. The router restarts, and the wireless connection is good. Next day, I have to do it all again. Why doesn't the wireless connection work without me having to do this?
Posted by foof567 on
sandeep
    New Friend:
Yty
Posted on Oct 07, 2012
Chris Hingee
  • D-Link Master
  • 32,281 Answers
I haven't come across this problem before.
Try resetting the Dlink back to the factory defaults and configure the Dlink again.
Power off the Dlink for a couple of mins. then power it up and press the Reset button on the back of the Dlink for at leasr 5 secs. until the LEDs flash, then configure the Dlink again. If you use different SSID and encryption settings etc., then you need to configure the wireless card in the computers with these settings
Posted on Nov 28, 2009
Wbr-2310 dlink router wired connection issue
connect your computer to the router by an ethernet cable. Open Internet explorer or FIREFOX. Type the roiuter's default IP-address (if not known: its either 192.168.0.1 or 192.168.1.1 or 192.168.0.0 or 192.168.1.0... keep trying until you're answered and asked for the password to enter the router (either attached on the router, in the manual or try: user: admin password: admin or password: password. Whgen you're in you'll find many checkboxes you could fill oput or notr; Easyway: give your net a name (SSID), then choose the network access security (set it to wpa-psk), choose a password and enable DHCP (then the router does the rest). Disconnect, look if the computer sjhows reception of your netwoirk by displaying its name. then connect. You will be asked for the password you chose. Done.
Jun 04, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I have a Gateway nv52 laptop and a dlink wbr 2310 wireless router. I can not connect to my network, but I can connect to my friends syslink. If I plug right in to the main motorola router, I get...
So that means you are able to connect to the network with the ethernet cable only.
Did yopu try to connect to the wireless network ?
And if yes then what was the error message ?
Click Here for more info about wireless connection. Pl. go through the web site you will get the answer !
Oct 10, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Lost the cd to my d-link 2310
Go to this link:
http://www.dlink.com/products/?pid=470
Proceed to download required software.
Remember to give a good rating for a good comment! Thank you for using fixya.
Aug 04, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Dlink wbr-2310 router no wireless working
you have to change your channelk type in your wi fi router.
For that access your router with following link
http://192.168.1.1 or
http://192.168.0.1
if you have belkin router
http://192.168.2.1
type user name as "admin" and password is "admin" or blank or "password"
then go to wi fi ->advanced setup chang channel type 4 ,6 ,11
change chanel type 1 by 1 and check signal strength.
everyt time save settings and restart both computer and router after save settings.
Thanks for using fixya.
Please rate this solution if it helps.
Jul 23, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Wbr 2310?
check wther your wireless in on and even check that on router mac filtering is on,problm mite b your laptop is not getting detected by your router,jus check wther both are on,
Mar 18, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
D-link WBR-2310 Stop working
Sounds like a defective modem/modem failure if, it does not reset or if you take all of the other wires out and just leave the power in and none of the other lights go off then that is definitely a defective mode, I suggest either returning the modem to where you purchased it from or calling D link it should be covered under there warranty for replacement.
Nov 14, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link (DI-784) Wireless Router Logo
160 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
