Question about NEC Electra Elite DTU 16D-2 Corded Phone
Disable automatic answer when picking up phone
Is there a way to set the phone not to automatically answer a call when you pick up the phone? I would like to have to press the blinking line to be able to answer it.
william bennett
  • 945 Answers
Http://www.chickasawtel.com/pdf/manuals/elitemultilineug.pdf
Click on the above it will take you to your manual.
Hope it helps
Posted on Nov 28, 2009
Hello! We just purchaesed a Brother FAX 2840. Set up was no issue at all, sending out faxes with ease. Sadly it wont receive any unless I pick up the handset and press start.
WHERE IS THE REC MODE SET, SHOULD SHOW ON THE DISPLAY, IN MENU SETTINGS, SET REC MODE TO AUTO. DO YOU HEAR A RINGTONE WHEN YOU PICK UP HANDSET. IF NOT CHECK WHERE TELEPHONE CORD IS PLUGGED IN SHOULD BE LINE, SOMETIMES PEOPLE PLUG INTO EXT PHONE...
Aug 16, 2018 | Brother Office Equipment & Supplies
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
My answering machine (phone line) is picking up when I dial my fax number. How do I set my fax machine up so that it will pick up when I dial the fax number?
Either your fax machine is set to answer on more rings then your answering machine is or you dont have the automatic answer key pushed?
Determine how many rings your answering machine picks up on and then change the number of rings to a lower amount on your fax machine. To change the number of rings before picking up the line, press the "menu" key on the fax machine and use the up and down arrows to scroll until you find the "basic fax set up" or the "advanced set up" areas. I am not sure which one will have the number of rings setting. Try looking in both until you find it.
when you see it press "ok" or "enter" get in and change the amount of rings before answering. call your fax machine to make sure it picks up before your answering machine.
This should solve your problem.
Mar 21, 2011 | Office Equipment & Supplies
I hooked up a phone in the office on an extended line from another area and all of the memory buttons automatically worked, but the phone doesn't ring even after using feature *6 selecting a ring, and...
The easiest thing to do is use Direct Pickup Feature.
When the phone is ringing dial Feature 76
Dial internal number of a phone that is ringing (also refered as extension number)
You just answered a ringing phone at your desk.
If you have login information for Feature **config, I can help you set up your phone to be ringing as well.
Cheers
Jun 24, 2009 | NorStar M7310 Corded Phone
Norstar M7310 phone doesn't ring and doesn't pick up calls
You can look at the manual here:
http://www.fixya.com/support/p98000-norstar_m7310_corded_phone_nt8b21ac03/manual-34096/page-3
I have a hp 2200 all-in-one printer. For some
if it sends ok, then it has probably been switched to "manual receive" form "automatic mode"
Apr 21, 2009 | Office Equipment & Supplies
ANSWERING A CALL AND NON FUNCTIONING ANSWERING SYSTEM
no make or model listed
on many phones there is an ability that when the phone is picked up it is automatically connected to the caller and pressing the answer button is the same as hanging up
as for you second point , if a caller rings but hangs up before the message beep or after the beep but hangs up , there will be no message recorded
Nov 15, 2017 | General Electric 29115AE1 1.9 GHz 1-Line...
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Pick up handset to answer a call and NOT have to press a line
if your phone had set for ringging assignment, u no need to press any key to answer the call.
check the indicator light,
if green light turn on, u can direct answer the call
if red light turn on, u ned to press the line to answer the call
kindly ask the phone provider the set yr extention for incoming ring assignment
Nov 12, 2008 | Toshiba DKT-2020 Corded Phone
Receiver dosen't pick up line that is ringing
go to programming section 5
You want Automatic Line Selection
Press feature00
left intercom button press twice (system program)
press right intercom once (central tel program)
enter # of extension to be programmed (intercom #)
press **
press line buttons in desired order line1 line 2 etc and
end with left intercom then press**
enter feature 00 to exit programming
Dave
Aug 26, 2008 | Avaya Corded Phone avaparp18d
NEC Electra Elite DTU 16D-2 Corded Phone Logo
371 people viewed this question
Top NEC Lands Phones Experts
Ekse
ray gallant
Andrew Taylor
Andrew Taylor
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
