Question about Canon imageCLASS MF8170C All-In-One Laser Printer
What does it mean when the printer says "prepare new k cart"
Posted by janetjrolle on
Adnan Bhatti
    President:
  • 1,188 Answers
It means that the black ink cartridge is going to be used up soon so you would better get a replacement at hand to avoid interruptions.Probably REPLACE K CARTRIDGE will appear sometime later.
To replace cartridge do as follows:
Get a Black (EP-87) Toner Cartridge.
  1. Press <Menu>.
  2. Press <What does it mean when the printer says - la.gif> or &What does it mean when the printer says - ra.gifg data-src="/uploads/images/ra.gif" alt="ra.gif" class="h_mi" />> to select [MAINTENANCE], then press <Set>.
  3. What does it mean when the printer says - ra.gifss <la.gif> or <ra.gif> to select [CHANWhat does it mean when the printer says - ra.gifTRIDGE], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select the cartridge to be replaced, then press <Set>.
    What does it mean when the printer says - open_scanning_platform_open_cartridge_cover.gifi class="h_mi">Lift the scanning platform and open the cartridge cover when the sound of machine operation stop.
  5. Make sure that the toner cartridge you want to replace is at the position for replacing.
    Ifthe spent toner cartridge is not in the replacement position, close thecover, then open it again whWhat does it mean when the printer says - remove_toner_cart.gifne stops. Repeat thisprocess until the cartridge you want to replace is in the correctposition.
  6. Remove the toner cartridge from the machine.
    Hold the grip on the toner cartridge and lift it straight up.
  7. Confirm the color of the label on the toner cartridge holder,then take out a toner cartridge of the same color from the protectivebag.
    Open the protective bag with scissors, so as not to damage the cartridge.
    • Keepthe protective bag in which the cartridge came in. It may be requiredwhen taking out the toner cartridge for machine maintenance.
    • Becareful not to hold or touch the prohibited portions such as the sensoror What does it mean when the printer says - shake_cart_evenly.gifIt may result in damage to the maWhat does it mean when the printer says - important.gifimg src="/uploads/images/dont_touch_cart_contact_sensors.gif" alt="dont_touch_cart_contact_sensors.gif" class="h_mi" />
  8. Hold the toner cartridge as shown in the figure, shake it gently 5 or 6 times from side to side (1), then back and forth (2) to evenly distribute the toner inside.
      Iftoner is not distributed evenly, it may result in a deterioration What does it mean when the printer says - important.gifuality. Be sure to carry out this procedure properly.
    • Be sure to shake the toner cartridge gently. Toner may spill if the cartridge is handled without caution.
  9. Remove the protective cover. Hold the protective cover and remove itWhat does it mean when the printer says - dont_touch_developing_roller_cart.gifc="/uploads/images/remove_protective_cover_cart.gif" alt="remove_protective_cover_cart.gif" class="h_mi" />
    It may be a little snug, but it will pull off.
    • Donot touch or hold the developing roller. The image quality maydeteriorate if you do. DoWhat does it mean when the printer says - pull_out_sealing_tape.gifoner cartridge memoryor bring iWhat does it mean when the printer says - caution.gifetic waves as this may result in damage to themachine.
    • Keepthe pWhat does it mean when the printer says - important.gifer with which the cartridge from removed. It may berequired when taking out the toner cartridge for machine maintenance.
  10. Place the toner cartridge on a flat surface, then What does it mean when the printer says - dont_pull_tape_at_angle.gifpprox. 45 cm (17.72") in length) while supporting thetoner cartridge.
    Hold the tab on the sealing tape and pull it straight out.
    Ifthe sealing tape is pulled out forcefully or stopped at midpoint, tonermay spill. If toner gets into your eyes or mouth, wash it awayimmediately and consult a physician.
<ul class=
  11. Donot pull the sealing tape diagonally, upwards, or downwards. If thetape is severed, it may become difficult to pull it out completely.
  12. Pullout the sealing tape completely from the toner cartridge. If thesealing tape remains in the toWhat does it mean when the printer says - close_cart_cover_lower_scanning_platform.gifon in print quality.
  13. Dispose of the sealing tape according to local regulations.
  14. Hold the grip on the toner cartridge and install it in the machine.
    Position the triangular mark on the toner cartridge with the triangular mark on the machine and instlal the toner cartridge.
    Whenthe toner cartridge is installed properly, the label on the cartridgeand on the toner cartridge holder will be aligned as shown in thefigure.
  15. Close the cartridge cover and lower the scanning platform.
    The toner cartridge holder will rotate automatically.
Posted on Nov 27, 2009
billgleaves
    New Friend:
Printer prints with red and blue 1" horizontal lines (red and yellow) across page??
Posted on Jul 08, 2011
3 Related Answers
Anonymous
SOURCE: canon image class mf 8170 problem
You need a new black toner cartridge.
Posted on Jul 30, 2008
Anonymous
SOURCE: Canon Imageclass MF8180c says prepare new K Cart,
It is telling you that you need to replace the black "K" toner cartridge. It has the yellow "Y", magenta "M", cyan "C"and black "K" cartridge. You need to have the drum roll over until you can see the black cartridge when you open the printer top.
Posted on Mar 19, 2009
Tim Swiercinsky
  • 1126 Answers
SOURCE: prepare new k cart
K cart is black toner. Around $100 unless you buy a compatible cartridge. Try this link...
http://www.precisionroller.com/toner-cartridges-for-canon-imageclass-mf8180c/products.html
Posted on Jul 14, 2009
Hello. My HP Designjet 800ps says "too little ink to prepare the ink system". I want to know if there is something that i can do to erase this error.
It sounds like the printer has been set to initialize as if new and thinks that there is no ink in the tubes so it wants to do a full prime. Other than replacing the carts and letting it run I am not sure there is another way.
Apr 07, 2015 | HP DesignJet 800ps InkJet Printer
When I removed the fuse the printer will print again but it wont print properly it will just turn the paper black. will should i do?
Dear
It seems that the toner cart. was refilled and the fuse supplied by the re-filler is not the right one. The right one is (65mA fast acting 5mm type). The meaning of the fuse is to count and inform the user about the status of toner remains and send warning massage to prepare for new toner.
For black print, some here the electrical contact path has missed/loosen etc at the cart right side, these points are to be cleaned and lubricated properly. Also over flow of toner will cause such problem due to mis alignment of the internal parts.
Thanks and Happy new year 2015.
Aug 03, 2014 | Samsung Office Equipment & Supplies
PREPARE NEW Y CART
Hey!!Its the yellow cartridge that needs to be replaced!!Enjoy!!
Nov 12, 2010 | Canon imageCLASS MF8180C All-In-One Laser...
Prepare new k cart??????
k cart is the Black Ink Cartridge. You are obviously low on ink.
Aug 05, 2009 | Canon Office Equipment & Supplies
Says Cartridge error 50C...what does that mean?When the printer is turned on, it flashes this message, but I can't find it in the manual or online.
hi : shunaswim
the error 50 c means either a cartridge fgone bad or the carrrier inside the printer gone bad .,
possible reason ., : having intalled faultly cart . if u got  refilled cartridge ., then contact retailer .,
if got a new cart from dell ., call them @ 18006249896 and get a replacement cause the carts have 2 yr warratny on them ., make sure u call them along with the order # of ur purchase .
most importantly :
u need to know which cart is causin the problem : black or the color .,
try one cart at a time ., if both the cartridges have the same problem ., the n repalce the printer or the cartridges .
hav a gooday !
Jul 27, 2009 | Dell A960 All-In-One InkJet Printer
Prepare New Y Cart is the error message. I see it
The copier is almost out of yellow (Y) toner so it is telling you to make sure you have a spare one available for when it does run out. Get it prepared/ordered. It will eventually tell you that it is time to replace the yellow toner.
May 13, 2009 | Canon Office Equipment & Supplies
Canon Imageclass MF8180c says prepare new K Cart, what does that mean?
Feb 17, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Color imageclass mf8170c
You Cyan cartridge is getting low. Buy one now because there is no warning to when it decides to up and quit and you wont be able to print anything!!!!
Jan 23, 2008 | Canon imageCLASS MF8170C All-In-One Laser...
Canon image class mf 8170 problem
its mean that change new drum cartridge
Oct 17, 2007 | Canon ImageClass D880 Copier
Canon imageCLASS MF8170C All-In-One Laser Printer Logo
592 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
