Write suzuki directly, or contact them,first try your local suzuki dealer , if that doesnt work try corporate offices. This is a very common problem that occurs alot in most suzuki's. I myself just bought a 2001 vitara 2 weeks ago & have the same problem. It starts up fine in the morning but if I stop somewhere with the car & let it idle , it starts to stall & shut off completely & then I have to wait 10 to 20 minutes before it will turn on. Suzuki should admit to this problem & have a recall. I have read hundreds of articles of people all over the states with the same problem. The dealers are telling everyone " well we dont know what the problem is". Its their JOB! They should know!
SOURCE: How to change the fuel filter on a suzuki grand Vitara
Fuel FIlter - Removal
To install:
Negative battery cable
Fuel lines from the fuel filter
Fuel filter
Fuel filter and tighten the bracket bolt. Note the fuel flow
directional arrow.
Fuel lines to the fuel filter.
To install:
Fuel filter
Fuel filter is incorporated in fuel pump assembly in fuel tank.
directional arrow.
Hope this help.
SOURCE: SUZUKI VITARA 2.0 V6 PETROL ENGINE
I suggest either a "Haynes" or "Chilton" repair manual. They are both very informative concerning complete engine tear down.
SOURCE: suzuki vitara kick down cable
From memory, the tranmission pan will have to be removed. This is messy, and care has to be taken to avoid contamination entering the trans. The cable has probably rusted from off-road use in water and now gear changes are very harsh and sudden.
SOURCE: Location of fuel filter 2002 suzuki vitara
Check the left (drivers side) frame rail in front of the fuel tank, near rear axle.
