The protection mode is there for a reason...the main one being to protect your speakers in the event that there is an issue with the amplifier. Bypassing the protection can easily result in the destruction of your speakers and the unit itself. Your receiver needs to be examined by a real live technician.
SOURCE: stuck in protect mode
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back
and see if you get rid of protect state. Sometimes accumulation of
electrostatic charges inside circuit capacitors can kick in protect
mode. In that case unplugging the unit from main for some times can get
rid of electrostatic charges, and reset circuits by draining power
completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number
listed on the owners manual, or asking a quote on repair to a local
technician.
SOURCE: Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
SOURCE: my sony receiver is stuck in protect
Hi, I had this very problem with my Sony 5.1 home theatre amp - after a few seconds it would go into 'protect' mode and would not play sounds. Having checked all the usual causes such as wires/ shorts etc I took the outer case off revealing the 'workings' and just tightened up every cross head screw I could find. Since then it has been perfect. Might be that I had a bad earth???
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
how to bypass protection mode on my sony receiver
