This is a 6 brush model, the brushes do not rotate, the filter is clean and the switch is in the on position
The brush system on this model has a poor engineering design in that the brushes are running off an air turbine, which uses a steel bushing to spin the turbine which gets rusty from the moisture when the machine is being used. No long term solver. I would replace the machine with a Dirt Devil Platinum Force model
If you are not looking to buy a new $200 machine you can replace the Turbine Gear for $32. Follow the link below.
Hoover SteamVac Replacement Turbine Brush
Gear Part # 91001097 replaces part numbers 43191006 and 43191018
Hoover F74XX Parts Link
http://www.usavacuum.com/Hoover-Steamvac-s/109.htm
