Question about Malber P21 Front Load Washer
I have a used malber p18. all the hoses are
I have a used malber p18. all the hoses are connected but the washer will not fill with water. What can be wrong?
    Genius:
  • Malber Master
  • 1,481 Answers
Ok. Assuming that the water is turned on, and the electricity is ok it should fill, if not check is machine dead or able to function in other ways if alls ok then replace the solonoid valves that allow water to enter..Hope this helps.
Posted on Nov 27, 2009
Water leakage at the faucet connection. is it a new D280 that i need? this one is only 2 years old but i can't think of any other reason. now that joel is gone, who do i call in nyc? thanks, j
These European machines have "English" (Whitworth) threads on the hose connectors. They look like American standard (NPT/NPS) threads used on everything here in the States, but are slightly different. Consequently, your hook-up hoses are special, having American NPS threads at the faucet end, and Whitworth threads at the Washer end.
Buy them from Malber. You can find Malber Distribution Corp online, or call them at 516-323-5299. Tell them Mike, in DC, says hi.
Oct 26, 2012 | Malber WD1000 Front Load Washer/Dryer
I have the Malber WD1000,the wash cycle goes on but no water pumps out, a couple drops come out . How do i fix it?
No water fill
1.water valves closed----turn on valves
2. Hoses kinked---unkink hoses
3. Screen in fill hose clogged----clean out screen
4. No power to fill solenoid---replace solenoid
5. Faulty water level control---replace control
6. Machine did not turn on----check control & power outlet
Water will not drain from machine
1.kinked or clogged hose----clean drain hose
2.pump does not run----readjust & tighten pump-drive mechanism
3.suds lock----remove suds,, add cold water
4.faulty transfer valve---replace
5.defective timer----replace
6.loose belt---adjust belt
Sep 22, 2011 | Malber WD1000 Front Load Washer/Dryer
We would like to use a two hose water supply at our new location and until know we have only supplied water to the washer using one from the kitchen sink. After taking off the plastic cape from the 2nd...
there may be a valve or stopping tap inside the maching that needs to be opened.
do you have the correct pipes on the correct inlets? if the wrong way round the machine
may only take hot thinking it is cold.
i hope this was useful
Jan 11, 2011 | Malber P21 Front Load Washer
It started leaking when filling with water...why?
I've had to replace the internal hose three times where the water connections are. It is a "Y" hose, that is not sturdy, and a defective design. I've had this washer for three years, and this keeps happening. If you look carfuilly, you'll find a hole at the "Y" junction.
Feb 22, 2010 | Malber P21 Front Load Washer
I have Malber WD1000. Hot water run through the pipe, but do not fill machine. How can I find and check the filter of hot water in machine
Hello. Just turn off the water and then remove the fill hose which goes from the water faucet into the back of the machine. Examine the entire hose and pay closest attention to the filter located at the end of the hose nearest the faucet. regards, Joe
PS - please rate my answer as helpful Thank you.
Feb 08, 2010 | Malber WD1000 Front Load Washer/Dryer
Kenmore 110 Washer fill hoses flowing the wrong way...
Both hoses must be connected to a valve or capped off.
Jun 08, 2009 | Kenmore Washing Machines
Water in drum after turning off
could be a leaking fill valve ..not shutting off good after shutoff
Dec 08, 2008 | Malber WD1000 Front Load Washer/Dryer
Snap-on spigot coupling won't stay connected
Sounds like too much water pressure or, more likely, the coupler has worn down. You can get a replacement at most hrdware stores.
Nov 03, 2006 | Malber WD1000 Front Load Washer/Dryer
My washing machine won't fill with water
I have my washer connected to the kitchen sink. In order for it to fill I have to connect the hose to the faucet and turn it on, it is pain but that is the only way it will work for me. I hope this helps.
Sep 15, 2006 | Malber P21 Front Load Washer
Malber P21 Front Load Washer Logo
198 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
peter gittos
peter gittos
Jason Harris
Jason Harris
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
