HI WHILE PRINTING THE LABELS ON THE BARCODE PRINTER MODEL NO. B-SA4T Toshiba Printer , ONE LABLES GETS PRINTED THEN THE OTHER IS BLANK , THEN ONE GETS PRINTED OTHER IS BLANK . PLS ADVICE ME WHAT TO DO
This is due to : Wrong size of label. You must give a page size and the gap size It is very important to give the correct height and ga dimensions The detecting sensor chosen is not the right one
If you mean Dymo labels and if the Dymo labels have a black rectangle on the reverse and if the labels aren't to wide, then the labels should work. You may run into problems with the Label printer advancing too far after printing; unfortunately, you will have to manually re-align the label after printing
We must establish whether the problem is a moving label or just that the labels are not aligned properly. Is hte printing split across the two labels consistant regardless of hte number of labels printed? If so, then the lables are not aligned properly. The user manual has the procedure for aligning these. This is part of the setup procedure.
If hte first line of the labels changes position on subsequent printings, then either the label size is not defined properly or the format being used is not correct. I don't have the manual handy at the moment so I can't give you the particulars, but if you could update this and tell me which of the 2 conditions you are experiencing, I will look up the specifics in the morning.
After you press print the window pops up with printing preferences, select preferences and tell the printer you are printing labels, it will allow more time for the label to reach the start position and start at the right place on the label sheet.
what printer? do you have labelling software installed? or are you using just standard word processing?
you may want to get avery label software. it's specifically used for those types of uses (though you don't need to use their labels as long as the labels are using a similar layout).
you can find the software at most office supplies.
The MPF is simply the "Manual Paper Feed".
Your printer is set by default that the MPF paper type is "plain paper". Since you are telling the printer that you are trying to print lables, the printer is simply telling you that you need to load the MPF with lables.
If you say "ok", the printer sould continue and print the lables.
If you only print lables, the you can change the default paper for the MPF tray to "lables", and then you will no longer be prompted to load the tray.
May be your problems can be solved doing a calibration. To do this, turn off the printer, press the feed key and turn on the printer. When the led flashes in red quickly release the feed key, the printer will start to calibrate and after the calibration will feed one label.
Have you gone into your print driver and changes the settings there?
I am not sure with your inormation if you have changed the settings on the printer or in the driver.
What it sounds like is happening is that there is a mismatch between the printer and computer.
It may even be set so that it is looking for lables in a bypass tray.
Somewhere there is a mismatch in information as to where the labels are loaded.
Start at the driver properties page and confirm every step in your setup.
