Nikon D80 Digital Camera with 18-135mm Lens Logo
Posted on Nov 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Err with f4 and r11 display - Nikon D80 Digital Camera with 18-135mm Lens
Anonymous
Level 2:
Novelist:
  • Expert 181 Answers
  • Posted on Jan 08, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
181
Questions
0
Helped
86318
Points
305
If your lens has an aperture ring, do note that most of these lenses require the ring to be locked at a certain position for it to work. In the course of using the lens, you may have accidentally unlocked the aperture ring and moved it out of position. This is a common problem.
To fix this error, try this:
1. Turn off camera
2. Turn the aperture ring clockwise and then lock it
3. Turn on the camera
If you still encounter the same problem, repeat the same steps but turn the aperture ring counter-clockwise. Hope this helps.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
673
Points
Nikon d80 err "lo f5.3"
2answers
My Nikon D80 has error message, what can I do
R11 is not an error message it is the number of shots left before the image buffer is full and you have to stop taking images untill there is space in the buffer
When the indoor unit is on F4 fault error code display.please help to solve the problem.
f4 mean Air Conditioners Questions & Answers - Fixya
www.fixya.com > Forum > Tags > f4 mean
My gree split type ac error F4 what is problem Name of malfunction = Outdoor tube sensor open or short circuit Display of double eight code = F4 this means
When using oven F3 or F5 comes up on the digital display and it beeps. Sometimes it says err on it. Very frustrataing, use my oven a lot.
Replace the temperature sensor first. It may solve both problems. If not,the clock will have to be replaced too.
F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
2helpful
MY FORD TAURUS 1996 IS RUNING AND SUDENLY STOP AND IS DEAD, WHY.
tv1709~us~en~file=adobe.gif~gen~ref.gif Printable View (11 KB) Article No.
97-17-9
  • STALL - ON DECELERATION AND/OR INTERMITTENT STALL IN WARM WEATHER - VEHICLES BUILT THROUGH 8/18/96 AND SHO BUILT THROUGH 8/6/96
Publication Date: AUGUST 18, 1997
FORD: 1996 TAURUS SHO, TAURUS LINCOLN-MERCURY: 1996 SABLE This TSB article is being republished in its entirety to correct a service part number. CALIBRATION: 6-10A-R07, 6-10A-R10, 6-10A-R11, 6-10A-R12, 6-10S-R07, 6-10S-R10, 6-10S-R11, 6-10S-R12, 6-10B-R06, 6-10B-R10, 6-10B-R11, 6-10B-R12, 6-10T-R06, 6-10T-R10, 6-10T-R11, 6-10T-R12, 6-14A-R07, 6-14A-R08, 6-14A-R10, 6-14A-R11, 6-14S-R07, 6-14S-R08, 6-14S-R10, 6-14S-R11, 6LDA-JAD tv1709~us~en~file=caution.gif~gen~ref.gif WARNING: THIS MODIFICATION IS AUTHORIZED ONLY FOR THE LISTED ENGINE. PERFORMING THIS MODIFICATION ON OTHER ENGINE CALIBRATIONS IS UNAUTHORIZED AND COULD CREATE LIABILITY UNDER APPLICABLE FEDERAL OR LOCAL LAWS. ISSUE: Some vehicles may stall on deceleration and/or have an intermittent stall in warm weather. This may be caused by the vapor control valve not supplying a steady flow of fuel from the tank to the intake manifold.
ACTION: Replace the fuel tank, vapor control valve, fuel fill tube cap and clamp. Install heat shield over fuel tank and reprogram the Powertrain Control Module (PCM). This should reduce the possibility of stalling. Refer to the following text for details.
Perform all diagnostics for stalling by following the procedures outlined in the 1996 Powertrain Control/Emissions Diagnosis (PC/ED) Service Manual and 1996 Taurus/Sable Service Manual, Pages 03-13-5 through 03-13-8. Check to be sure Grounds 401 (sedans) and 400 (wagons) are secure. Check for a kink in the canister vent hose and repair as required. If no other concerns are found, reprogram the PCM using the latest level CD-ROM update disc and refer to the following PCM Application Chart for correct PCM usage. Replace the fuel tank, vapor control valve, and vapor management valve by following the procedure outlined in the Instruction Sheet included in the Fuel System Service Kit.
PCM APPLICATION Old Calibration Old Part Number (-12A650-) New Calibration New Part Number (-12A650-) 6-10A-R07,R10, R11, R12 F6DF-BF 6-10A-R12 F6PF-CVB 6-10S-R07,R10, R11, R12 F6DF-DF 6-10S-R12 F6PF-CYB 6-10B-R06,R10, R11, R12 F6DF-JD 6-10B-R12 F6PF-CXA 6-10T-R06,R10, R11, R12 F6DF-KD 6-10T-R12 F6PF-CZA 6-14A-R07,R08, R10, R11 F6DF-EG 6-14A-R11 F6PF-CGA 6-14S-R07,R08, R10, R11 F6DF-FG 6-14A-R11 F6PF-CFB 6LDA-JAD F6DF-RD 6LDA-JAD F6PF-CDA
I'm using Tokina 12-24mm f4 on my Canon EOS 20D.
Most likely something bad has happened. It out of warranty, usually its 5 years. This is a pro job, getting to anything inside a lens is a very special job. There are a number of places to send it out. Check http://www.acecam.com/srindex.html and write to one or two of the places for estimates. It could be $150 or more plus shipping and taxes. A new one is about $400+, you could check around the many on-line camera stores for a used one. Could be a simple electronic part or the iris blades are bad.
8helpful
Which function key allows to switch to tv
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4    ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
1992 Frigidaire built-in oven with F4 error
f4 is the code for a shorted oven probe try first replacing it
2helpful
Err Err err err err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
