The thermostat is located in the back, behind the back panel and mouted on the air discharge from the drum before it entered the blower that blows it out via the vent. They are normally snap-disc style thermostats and can be ordered from sears parts direct online or purchased at most sears appliance parts stores. Gas dryers also have at least two over-temperature devices to prevent an overheat condition that may lead to a fire. One is normally a snap-disc thermostat (some with a manual reset) and the second is usually a thermal-fuse that must be replaced...not reset. 110 gas dryers use a lot less electricity than 220 electric dryers since all they have to do is turn the drum and blow the air (heat comes from a gas flame) where the 220-volt electrics have electric heating elements that comsume large amounts of power. Yes, I would consider then safe as long as they are vented correctly.
what makes you think has a bad thermo?gas dryers use less power than electric.
