Check phone line. use a normal phone and plug into the same phone wall socket that the MFP is using, do we have a dial tone? Do we have a noisy line, any buzz or crackel will cause issues
If there is no dial tone ring line supplier, If it is noisy line do the same
Also check phone line is plug into "line" socket in the back of machine not "ext'
Also check no prefix is required to dial out, unit needs its own phone line..
Also try using resolution of fax as standard not fine, this requires less info to go threw the line
In Australia we have a thing called folds (fax online diag service), basicly it is a fax number you ring and the phone company who own the line send back a report, most times the issue is noisy line or no line available
hope this helps
Cheers
Soulvisitor
