R6025 - Computers & Internet
Posted by rhock759 on
reyberbegal
    New Friend:
  • 43 Answers
The R6025 Runtime Error happen when an application indirectly calls on a pure virtual member function from an invalid Microsoft Visual C++ run time library.
Posted on Jul 06, 2011
Bill Schilz
    President:
  • 2,049 Answers
Runtime error R6025
- pure virtual function call
This error occurs when your application indirectly calls a pure virtual member function in a context where a call to the function is not valid. In most cases, the compiler detects this and reports the error when building the application. But depending on how your code is written, sometimes the problem is detected only at run-time.
Cause: The error occurs when you indirectly call a pure virtual function within the context of a call to the constructor or destructor of an abstract base class. This is illustrated in the sample code below, along with some more description.
Solution: Calling a pure virtual function is a programming error, so you need to find the call to the pure virtual function and rewrite the code so it is not called.
One way to find a call to a pure virtual function is to replace the pure virtual function with an implementation that calls the Windows API function DebugBreak. When using the debugger, DebugBreak will cause a hard-coded breakpoint. When the code stops running at this breakpoint, you can view the callstack to see where the function was called.
Another way to find a call to a pure virtual function is to set a breakpoint on the _purecall function that is found in PureVirt.c. Breaking on this function has the advantage of keeping the stack intact so that you can trace what is occurring.
Posted on Nov 27, 2009
With Roxio 2012 the Photo Suite application will not work. The error says runtime error, program c, R6025 pure virtual call. How can I make Roxio's Photoe Suite work?
Uninstall the program. Clear the registry of all Photo Suite entries and then re install the program. To make this extremely easy download a program called Advanced Uninstaller Pro. It's free and works great.
Sep 25, 2014 | Computers & Internet
R6025 error
r6025 Error Codes are caused in one way or another by misconfigured system files in your windows operating system.
So, If you got r6025 Error then I strongly recommend that you Download (r6025) Repair Tool.
Jan 01, 2014 | Computers & Internet
Photoshop 5.5 r6025 error web
If the operating system is windows 7 or above the XP software will not run, it has to be compatible with windows 7 up.
Apr 20, 2017 | Adobe Computers & Internet
Error r6025 windows 7 quickbooks 2012
Solution 1: Use a different template when you're sending email or batch emails
Solution 2: Microsoft Visual C++ may not be installed or may be damaged
Solution 3: Repair QuickBooks
Solution 4: Run reboot.bat
Solution 5: Perform a clean install of QuickBooks
for more help visit QuickBooks Technical Support
Nov 14, 2012 | Computers & Internet
I recently purchased Vin Diesel Wheelman for the PC. I have a Windows Vista with a great amount of free space and meet the requirements. I was able to finish installing it but when I tried to play it, it...
The game is requesting a driver that does not exist, so a vital function call is denied. Both errors are driver related. I would reinstall any drivers you may posess. Graphics, sound, etc
Jun 25, 2009 | Computers & Internet
Runtime error R6025
If you are using Vista, Make sure it has nothing to do with the Aero Effects.
or
Make a AVI file what works until now perfectly, and then in a new project with this only file a make the disk.
Jun 17, 2009 | Adobe Photoshop Elements 6: Windows
Toshiba flash cards stopped working
go to Toshiba web site. they have your problem solution.
Dec 20, 2008 | Toshiba Satellite A105 Notebook
IE XP Runtime Error. Message R6025 Pure Virtual Functional Call
ALL IT MEANS IS THAT IT IS TAKING TOO LONG TO DOWNLOAD AND IS QUITTING ON YOU.
Video cards need to have a faster prosessing time than audio. Live streaming (video needs more room in you computer to process) and you may need to upgrade your RAM memory(random access memory). IF it is no more than 512mb. I am in the same situation and bought another 512mb card to take care of the problem. I have XP pro and the live streaming comes through and breaks up and stalls.
Oct 08, 2008 | Microsoft Windows XP Professional
C runtime error Program...\es\Roxio Creator 2009\Roxio Central 4\RoxioCentralFX.exe R6025 -Pure Virtual Function Call
did you upgrade to Internet explorer 7? try to revert back to IE 6 or uninstall IE 7
Oct 05, 2008 | Computers & Internet
Computers & Internet Logo
630 people viewed this question
Ekse
Marvin
Marvin
