Question about Wacom Graphire Intuos Pen (GP300ESE) Digital Pen
My pen worked fine for years, now it jumps. I can't draw a straight or curved line anymore. It starts working then begins jumping.
Anonymous
Opened it up, inserted a screw driver and re-set it. Works like new!
Posted on Nov 27, 2009
1helpful
2answers
I have a 2002 chevy cavalier. Battery is 2yo. Car will take a jump. Does not make any clicking noises, and lights,horn,radio work. Car would not start day 1,got jump ran fine,day 2 needed jump again, ran...
Weak connection between battery post and cable. Since the jumper cables bypass this, by clipping on the cable ends, the car will start with a jump. Takes less current to start a warm car than a cold one, hence it starts all day. I would look closely at the cable ends where they attach to the battery. Clean them until spotless with baking soda and water and terminal cleaner brush.
If this does not solve the problem, clean the chassis ground on the other end of the - battery cable and + cable where it connects to the starter.
Check your alternator output also. Battery should not be defective in 2 years.
Possible current drain when key is off. Put a voltmeter inline with the battery and check for draw. If you get more than a few millivolts something is on and drawing current. Glove box light maybe? Check by pulling fuses until you find the source of the draw.
How do i use adobe illustrator?
Illustrator uses vector drawing tools, which require you to start with a range of points that are connected by lines... and contained areas are filled with color automatically as you draw. Look for the pen tool in the pallette, click points and watch them be joined by lines. To draw a curve, click and drag slightly before moving to the next point. This leaves a curve point, that has a set of handles you can manipulate. Good luck!
Wont start without jump and has new battery
You have a draw that is killing the battery. Search for more answers under battery draw.
Wavy lines when I try to draw straight lines.
same too me.on my old pc.that center thing was working fine.there wasnt any vibrtion at mouse pointer.i cant explain but i know same problem here..mouse pointer slips
1helpful
Tooya Pro with mac
They have bad products and i advice any one not to buy it . Bamboo pen is better , cheaper .
I had the problem that the pen does not work like mouse anymore , i mean without contact with the tablet , i sent them the pen to california to fix it and they said "we test it works fine and we change it with new one" and before i sent it i put a mark in it so i will know if they change or not , but i got the same one . They lie and their product really crappy .
Photoshop and WP5540 compatibility
get PS cs3, never had problems with that one, i own a genius 8X6 and it was perfect, yeah i know it sucks cause i brought cs4, but well, gotta wait till those guys from adobe fix that problem
G-Pen F610 - Cursor is jumping to the left
You should try to replace the tip of the pen, that's how I solved it.
3answers
Doesn't respond to the pen well
I had the same problem, and my fix was really simple. Did you make sure that your mouse and pen aren't on the tablet at the same time? I took my mouse off the tablet, the pen immediately stopped jumping around.
1helpful
2answers
My cursor was smooth and easy to draw with, but now it's all shaky and won't draw well!
the latest drivers have 2 modes...
1 open the driver control panel
2 at the top of the window double click the intuos3 tablet that is giving you problems
3 choose standard mode instead of recognition data
... this is at least what worked for me. I hope it helps.
Wacom Graphire Intuos Pen (GP300ESE) Digital Pen Logo
Top Wacom Computers & Internet Experts
Ekse
k24674
 Grubhead
Grubhead
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
