NetGear DG834G Router Logo
Posted on Nov 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power and internet lights flash slowly green & if i press reset button then power light flashes green to red. No other lights illuminate.
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 96 Answers
  • Posted on Nov 27, 2009
Anonymous
Expert
Level 2:
Mentor:
Answers
96
Questions
0
Helped
35506
Points
272
Try a hardware reset by holding in the reset button on the back panel (need a pin) for 20 seconds as you turn it on. If it does not work or you will not get connection from your router to cmputer it means the router has gone bad and need a replacement Let me know if this will help
Mod.Hp980PT, red and top green light flash, no heat
This is a very common feature on these types of simple, high-volume, low-cost home appliances known as a safety fault. This fault will temporarily (or permanently) disable the appliance and happens for several reasons: (1) an over-temp (high heat) occurrence, (2) an over-power (power surge) occurrence, (3) an under-power (power outage or trickle power) occurrence, (4) an over-time occurrence (auto-off fails), (5) a short-circuit occurrence (exposed/crossed/frayed wires, etc.). Fortunately, it uses a digital "fuse" system and can be reset by the user. However, there is no universal reset process on SoftHeat products so you just have to play with it until you figure it out (customer service dept is no help). Mine is a Kaz SoftHeat HP980PT, with a red power indicator/power-off button and 4 green heat setting buttons. Mine faulted after a heavy storm caused multiple power outages and power surges in my neighborhood. The green light on the highest heat setting button was flashing on mine. Here's how I fixed it: (1) unplugged both ends of power cord and straightened out the cord, then plugged back in to the heating pad end. (2) While holding down the flashing light button, I plugged back in to the wall outlet. (3) While still holding down the flashing light button, pressed and held down the red power-off button, then while still holding down the red power button, I released the flashing light button, followed by releasing the power-off button. This stopped the flashing green light and caused the red power indicator light to stay on (steady-on). It works fine now. Note: Some models have an actual hard fuse in addition to the digital fault feature or possibly only a simple fuse (without the digital fault system). These fuses can the found at many retail stores and then very easily replaced. I hope this helps some of you!!!
Canon IP5200R printer. Green & red led`s flash 20 times, pause & repeat. print head will not come out of park position on righthand side. Fault occurred while printing a photo error 6500 displayed
Hello!
Error 6500 or green and red flashes 20 times, mean hardware error. Particularly, the Logic Board Assembly
There are two possible fix: first is to reset the printer's waste ink counter and the second is to replace the Logic Board Assembly (part # QM2-2733)
Reset the Waste Ink Counter:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a
function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
For technical help:
  • For toll-free technical support, please call 1 (800) OK-CANON (1-800-652-2666) during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. ET, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
Hope this helps!
1helpful
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 • Cell Phones
Error 5100 on/off flashing and alarm flashing
Hello
Remove the error code 5100 1. Turn off printer. 2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color. 3. let go button Stop/Reset, continuing to hold POWER. 4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons. 5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key) 6.turn off printer by POWER button, then turn on. 7. You should be set. If it didn't work, try it again, slowly. It WILL work!
Hope this helps, if so do appreciate my effort by rating the solution Good Luck, Cmptrlink
2answers
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
I have a canon mp830 that is has trouble code 5c00 on the lcd. the power light and trouble light flash alternately green and yellow respectively. I've cleaned the print head. How can I reset the printer to...
Canon MP170, MP450, MP530, MP600, MP610, MP800, MP810, MP820, MP830, MP960, MP970
MX700, MX7600, MX850
1. Switch off the printer the button Power
2. Holding button Resume (the red triangle in ring), include the printer (press the button Power ) - an indicator fires green cvetom.
3. Holding button Power , release the button Resume
4. Not releasing button Power , two times press the button Resume and release both button.
5. After indicator of the cut-in/readiness flashing.. and fires constantly, fall into service mode.
6. Four times press the button Resume , under each striking Resume indicators are switched: green-yellow.
7. Once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера). For switching off the printer button Power press once again.
5helpful
2answers
Power light flashing green
the green power light is flashing green with the orange tick next to it and i cant get any wireless internet through it what do i do please help me
Stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
2answers
My xbox 360
Call Microsoft and send it back or go to www.llama.com to get the parts and instructions to fix it yourself.
1helpful
Actiontec (GS503AD3-01) Modem
--If the Power light is flashing red thanits definately problem with the Actiontec Router --As you have checked with different power source, the possibility of bad power source is no more --May be due to some voltage fluctuation the modem is gone bad.
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
