Question about Olympus Stylus 800 / ? 800 Digital Camera
Olympus Stylus 800 Camera , card cover open.
Basically, since April 14th 2009, My camera hasen't been working properly.
It says the, ''Card cover'' Is open. Whenever I turn it on, now I've seen the Copper, method. I just wanted to know, how do I do that? WIth My model type of camera. I didn't see a plastic piece fall out or anything, I just know one day it just decided not to work. I've done everything, Banging it against walls ( I was fustrated ) Blew it in, stuck pieces inside of every hole I could find. I'm just clueless right now.
Posted by PinkyPop on
5 Related Answers
Anonymous
  • 513 Answers
SOURCE: "Card-cover open" error message
It's when putting the card in.. typically you put it in and it clicks (so to speak).. if you delay removing your finger-push, it does something to the card and makes a Disconnect, although in looking at it, it looks just fine.. and the cover closes... A lot of people are reporting 'door open' errors. The micro-switch in the door housing is quite sensitive and pressure shifts from your hand on the door can cause it to trigger as if the door were opened. some get progressively worse. One fix is to add a little bit of length to the plastic that contacts the switch, either a layer of tape or a drop of epoxy, etc. This may help (or may not if the switch itself is flaky). Another fix discussed bypassing the switch altogether, obviously not for the faint of heart (or cameras in warrantee).
Posted on May 08, 2006
Anonymous
SOURCE: Card-Cover Open
Direct yourself to http://www.fixya.com/support/t115253-screen_keep_showing_card_cover_open
Posted on Jan 14, 2007
Anonymous
SOURCE: Olympus Stylus 770SW error message
After only 15 days mine did the same thing. I called the dealer Olympus and they gave me a RAN number and told me where to send it. I got a call about a week later. They said because the camera had moisture inside I was not coverd. The best they would do is mail me a rebate card for 25 dollars off my next purchase. I was like WTF. The woman said sorry but that was all they could do. When I asked to speak to manager she hung up.
Posted on Dec 05, 2007
Anonymous
SOURCE: XD mem card max for olympus D-560 Zoom
I hope this helps, I called Olympus for the exact same reason. The tech told me that the highest for the older D560 was 512mb. The other DX cards are for the newer models (same name!) that are 3D etc. effects of the newer models.
Posted on Jul 18, 2008
Randy Morton
  • 479 Answers
SOURCE: olympus 1030sw saying card cover open when its not
make sure the seals are clean of debris such as hair or sand, .. else it is repair
Posted on Jan 20, 2009
Turns off when cover is closed
First don't spent too much mont for repairs, because cameras are becoming cheaper and cheaper and in the mean while better and better.
You could try to open and close the cover several times and hope it starts working as it should. It has a switch connected to it, so the camera can see if the cover is open or closed. Now it is giving the wrong information. If the camera comes on, when the cover is open, that indicates the battery is still good, unless the it stops working within a short period of time.
3helpful
Have an Olympus Stylus Tough -6000 digital camera and when I turn it on a message appears on the screen that says "card-cover Open" and it won't allow me to operate the camera. The problem is...
remove the batteries and the card from the camera and clean it with something smooth and dry ...after that reinsert the card in th ecamera several times until it is recognised..this happens when the card it is not proper inserted ..or something is meesing with the sensor that detects the cover position...so a gentle cleaning inside will help also..
Dec 21, 2010 • Cameras
1helpful
Format Stylus 500
Press >menu< button, select >mode< select >card< select >format< select >yes< press >ok< (menu button)
During formatting DO NOT open battery cover, card cover, or plug in AC adapter.
Make sure you have all your files saved on your computer or elsewhere before formatting your card, since all images will be deleted.#
Hope that helps
Card cover open error message
Hi!
You need to make sure that the memory card is correctly installed on the camera and that its door lock is closed.
1helpful
Card cover open
The problem you are describing is a problem with a sensor that is on the card cover door. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.http://olympusamerica.com/cpg_section/cpg_servicerepair.aspOlympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $124 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Check card cover- Card cover open
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $100.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
"Card-Cover Open" Warning
Have same problem when camera is used underwater. Take out battery and xd card. Put camera in front of fan with lid open and facing fan for several hours.
Card cover error
the card , probably the memory card is not seated properly it will only fit in one way do not hit it with a hamer if it doesn't fit one way, turn it around 9facing the contact the other way, and try again
XD card error
What happens, is the file is corrupted when the camera shuts down while saving the picture. If you have a card reader try saving the pictures on the computer using the reader. You may have to reformat the card (in the camera).
Olympus Stylus 800 / ? 800 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Are you an Olympus Camera Expert? Answer questions, earn points and help others
