see this causes and fix it. God bless you If your microwave oven doesn't seem to work at all, check these:FusesDoor switchFusesUsually,
when your microwave oven doesn't work it all, the internal fuse
(thermal fuse) is blown. This fuse protects both you and the oven. When
it blows, you need to have a qualified appliance repair technician
replace it.Door switchIf
the fuse isn't the problem, check the door hooks and the door-release
button. When these are broken, the door switch doesn't activate, so the
oven can't work
1) taken apart and rebuilt cellphones and 2) dealt with hundreds of malfunctioning phones that didn't read SIM's, I'll give you some ACTUAL help.
1) remove the SIM and check for any missing pins in the slot. You can only see the first row of pins on the N1, but that's all you can see without taking the thing apart again. You should see 4 pins, but the one closest to the notched corner of the SIM doesn't really do anything.
2) If everything looks okay, reinsert the SIM, along with a couple pieces of paper. The idea is to press the SIM into the contacts in case the fit isn't as tight as before.
If you either see damaged pins in step 1 or step 2 didn't work, take it back to the repair guy. He broke it, he's obligated to fix it.
The first thing I would do is clean your battery connections very good. you may have to remove the plastic covers off the cable ends to get them cleaned good. Also make sure you get the connection bolts tight.
The key is stuck you have to be very careful if you are going to attempt to repair this.Turn the computer off and remove the battery before you attempt to repair it.Try prying it up with a thin knife blade.If this pops up and is working make sure it works as good as the other side.If not you will have to replace the palmrest.
Good Luck
Before you replace the switch try this. As you try to turn the key rock the steering wheel back and forth. The key may turn then, if so it was stuck due to pressure from the steering wheel lock. If it still doesn't turn yes the key and tumbler are bad.
What you can try is to remove the shift cables from the transmission side. then move the shifter and see if everything is free if it's still sticks then the cables are going to be replaced. if everything is moving with the cable off. then you need to remove the shift tower on the tranny (where the shift cable is I belive it's 5 bolts) remove the tower and you will see the shift pin. Inside the tower there is a cotter pin that breaks and that will cause you to have one gear and unable to selected another gear. If you are not mech inclined I would no attemped the shift tower repaire, the cables do it will save you money. The shift tower has bushings that can fall into the tranny.
First attach laptop to an external monitor and using the FN/ F keys toggle back and forth to the external display. If the external works OK then the video display adapter is fine and the problem is the TAB welds on the LCD. Time for a new LCD.
I had a similar problem and noticed I hit the F Lock button. On mine it was a one way plunger stuck down. This caused the problems you mentioned on mine. Prying it up with a paper clip had my unit working immediately. Good luck!
