Question about GE 30 in. JGP337 Gas Cooktop
The electronic spark continues after the burner is lit. It continues even if the burner is turned off. this continues for about a minute before it stops
Posted by golfngrand on
steve
  • GE Master
  • 3,361 Answers
You have one of your spark switches sticking. It may have come loose or possibly grease has migrated into it.
Remove the switch panel and check the switches for a loose or broken switch.
There is a switch behind every surface burner knob.
They must be seated firmly to work correctly.
Posted on Nov 26, 2009
The ignition - clicking - continues after burner has lit - all 5 burners have this issued
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Jul 31, 2011 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
All cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Nov 04, 2009 | Jenn-Air JGC8430 Gas Cooktop
When i turn on a burner, it lights, but all 5 igniters continue to ignite
I have the same problem all but one burner. When using the other burners the igniters keep sparking after being lit. What do I replace?
Oct 04, 2009 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Gas burners lit, but electronic ignition still clicks
Gas Range RepairBurners Keep on Clicking
heatman101
fsggfs
Mar 13, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Ignitors Continue to Spark
Turn the knob back towards off about 1/8 of a turn and you will take it off lite and it should fix it.
Aug 27, 2008 | Thermador 37 in. SGSX365 Gas Cooktop
Ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
May 01, 2008 | Cooktops
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
GE 30 in. JGP337 Gas Cooktop Logo
183 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
