Sylvania 32 in. Diagonal LCD HDTV Logo
Question about Sylvania 32 in. Diagonal LCD HDTV
My Sharp tv has vertical multicolored lines that
My Sharp lcd tv has vertical multicolored lines that dissappear after 20 minutes or so. Never been dropped or hit. Great picture after 20 minutes. Can I fix this? No warranty
Posted by Eva O'Handley on
  • Eva O'Handley Nov 26, 2009
    I don't know why this is coming up under Sylvania. It's a Sharp LC-32SH12U
Anonymous
    New Friend:
My new lc60le820un sharp is doing the same thing after two weeks. i called sharp they want to fix it. i want a new tv. after a few minutes of this i hung up and and called hh greg to replace it with a sony. thanks hh greg the sony is fine
Posted on Jun 14, 2010
Sharp LCD TV takes a long time to turn on
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sharp LCD TV Takes 20 minutes to warm up
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sharp LCD TV Takes Too Long to Turn On
Your TV main board is failing, soon it will not turn on at all, plan on buying a new one soon.
How may I fix colorful vertical lines on screen but clear voice on Sharp Aquos TV when I first turn it on?
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
What is wrong with Sharp Aquos LC-40C32U Picture
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search the site with the keyword "Line fault"
How to fix a Sharp Aquos LC-40C32U Picture
Multicolored lines run vertically on the screen. Is it fixable? not sure what happened. Tv was given to me. Can see the picture otherwise.
The tv could have a dead tv LCD screen panel because of it is damages by a person or an object by hitting it.Than the tv it is not worth it or repairable if it is require a new tv LCD screen panel.Will cost the same as a new tv,if tv require a new tv LCD screen panel replacement.The LCD screen panel tv that have multicolored lines run vertically on the LCD screen panel and people given it to u and said not thing.The tv probally have a dead tv LCD screen panel already,Sorry tv like this,it is a garbage tv now,it only can be used as a salvages tv only for it electronic circuitries boards only.
Multicolor vertical lines on one third of screen?
Unfortunately TV's aren't built to last anymore...once LED sets came out the life of them dropped in half over what they were 10 yrs ago.. 2.5 yrs isn't that far below average anymore. .There is a good chance you have Tcon board issues, you can try the old trick of cooking it in your oven and see if that helps since it started out as intermittent or would work for awhile and got worse but only about 20% at best of the time that works, you can find instructions on how to do it on youtube if you want to try, it won't hurt anything but chances are it won't fix it...next step is buy a tcon board but there are other things that could cause it , tcon would be where I would start
Top Sylvania Televison & Video Experts
Marvin
Marvin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
