I can't get a connection thru the router to the internet from a wired or wireless computer. When I remove the router I can get on from multiple computers. The wireless connection from the computer(s) to the router appears to be good. And the connection (cable wise) from the router to the cable modem appears to be good (I have swapped multple cables to be sure).
1.) Have you setup the router for use on cable modem?
2.) Run Your Setup utility that came on the CD for the router. And select Dynamic under the WAN settings unless you have a static IP address.
3.) If you do not have the CD to access the setup use IE Browser type 192.168.1.1. Select WAN settings and then Dynamic from the list.
4.) Make sure your computers are using the router and not the cable modem. Reboot your PC's and verify they work if they don't open the internet connections and view the gateway is 192.168.1.1?
Here is a link to the manual
