Question about Samsung HLP4663W 46" Rear Projection HDTV
My hlp4663 power comes on but no picture but has sound but only on the channel it was on last. Can't manually change volume or channel and don't have remote. When pushing on the power button the audio comes on no picture it will last 10 seconds and audio goes off and the lamp light and timer light are red, then it kicks back on audio only for 3 more times then shuts off. At this same time a loud noise from the back like the fan motor is working overtime. I have read on line all the repairs for the lamp and the ballast and the color wheel, i am not sure if these are the problems or is it the main board. Would appreciate any help before purchasing the wrong part to fix the problem.
Anonymous
    Problem Solver:
  • 4 Answers
Remove and check lamp
Posted on Nov 26, 2009
I have a sony bravia kdl-37v5810. sound on loud no picture buttons dont work on set or remote have to unplug to switch off.
Two pieces of information:
First thing to try is unplug the set and a box or receiver if you use them for several minutes from power, then plug things back for power and see if that helps.
Second, Sony is one of the few companies who uses the same access code to reset all their sets for the last 20 years, if it comes on and responds to the Sony original remote you can try that,
set is off, Then with the remote Display, 5, volume up, and power.
If set comes on you should be in the service menu---do not by accident touch any buttons randomly : what you want to touch is 8 (reset or write should appear on the screen in red, then hit enter and the word should change to green and the set shut off.
turn back on with remote and see what happened or not.
Dec 19, 2012 | Televison & Video
My toshiba model 46rf350 doesn't have a picture
OK!
Do you see any characters on your display? If yes: channel info, menu, volume bar? Means: you don't have any video info coming through. Main board is most likely candidate for replacement. Next scenario: TV powers up, but you see only display glowing, no characters, no info. t-con(display adapter) board is at fault.
Last one: you can hear the sound from TV speakers( not from your surround system), but display is "black". Power supply's ballast or "inverter" quit. If you answered "yes" to one of possible issues, give me more details, please. I will guide yourself over basic troubleshooting.
Good luck,
Alex.
Dec 09, 2011 | Toshiba Televison & Video
The picture went out on my plasma tv last night. i can hear the channels changing and the volume works just no picture. is that a blown bulb?
It may only be a power distribution problem which comes from age and leaving it on 24/7. This should only be a $100.00 fix unless you have a friend in the field.
Aug 16, 2010 | Akai PDP4294 42 in. EDTV-Ready Plasma...
The tv's green light comes on but there is no picture and no sound. When I push any buttons on the remote the only thing that shows up is the volume thing. It doesn't respond to pushing the channel buttons...
your main board has gone bad. Can be fixed, in my shop it would cost about $250. It is a real shame on the industry that these things last about 2 years or less. Hope you held on to your old crt style tv.
Jun 17, 2010 | LG 42LC2D 42 in. LCD HDTV
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
TV won't come on.
I Have this same problem, Open the box on the top of your tv and unplug the wire with the white plug. The tv will switch on but u can't change channel. Hope u have receiver to change channel. If u have solution for the volume, tell me please. Ty
Oct 06, 2009 | RCA F32650 32" TV
Sanyo DP19647...power comes on but no picture on screen. Any ideas?
Main Power Board is damaged, you have to replace but it´s an expensive part maybe the best is to buy a new TV
Sep 05, 2009 | Sanyo DP19647 19 in. LCD TV
''Hotel'' Viewing mode on Akai TV Model #CTS2550
Did you get an owners manual with the television?
Jul 01, 2017 | Akai CTS2550 25" TV
No picture
It sounds Like you Had Horz Failure In your Set,The Squealing you Heard was Probly the Horz Output Transistor,You will Probley have to take it to a Shop
Jul 17, 2007 | Insignia IS 20" TV040919 TV
Samsung HLP4663W 46" Rear Projection HDTV Logo
150 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
