Question about Evenflo Generations
I CANNOT get the arm-rests OFF!!!!! I read some solutions but they didn't tell me what I needed. I see the tabs you're supposed to push in so that the arm-rests will pull off, but I have pushed, pulled, pressed down and lifted them up... and still cannot get them off! What can I do? I HATE HATE HATE this stupid car seat! Why the hell did they make it so hard to get the damn cover off, so it can be washed and the seat itself, wiped down? WTF?!?!
Posted by roseisou5 on
  • marissa_john
    marissa_john Jan 05, 2013
    Thank you SO MUCH to all the people who posted the answer: use pliers to remove the armrests! I spent a week screwing around with those tabs and wouldn't have thought to use pliers. THANK YOU!!!!
Anonymous
    New Friend:
  • 4 Answers
Grab a pair of pliers! With the pliers, pull the bottom tab out towards you and slide the top tab underneath. Once the top tab is under the bottom, the armrest will pop right off.
Posted on Jan 21, 2010
Replace left armrest
If you have the new armrest it is pretty straight forward. There are usually only two screws holding these on that can be accessed from under the arm. If you have power controls on the rest they will have push in tabs and just snap in. I use a small screw driver and press in the tabs gently from the side to prevent damage as you get them out.
Apr 27, 2016 | Cars & Trucks
Tip
How to install a windshield wiper blade
You will need new wiper blades before you can perform a wiper blade replacement project. Get your "owner's car manual" as it will tell you everything you need to know about the wipers' size and type. The manual may also give you list of brands you can choose from for you wiper blades.
  1. Buy the correct wiper blades, make sure you have bought the entire blade and not just the rubber insert. Read the instructions properly before you begin. It will show you how to perform the wiper blade replacement.
  2. Take the wiper arms off the windshield. You will have to remove the old wiper blades very carefully so you don't hurt yourself. Wear kitchen gloves if you don't want to get your hands dirty or cut yourself.
  3. Push on the tab of the old wiper blades and pull them out. You can also use a small screwdriver to lift the tab.
  4. Take the new wiper blades and insert it in the arms very carefully. Don't push too hard, but do it gently. It will easily slide itself in. You will hear a "click" sound when the entire blade has gone inside.
  5. Wiggle or shake the new wiper blades to see they are secured properly and won't fly away when you turn them on. If all looks good, lower the wiper arms back on the windshield. And you're done!
on Jan 10, 2011 | Chevrolet Blazer Cars & Trucks
Frigidaire FDB956RBC1 top arm not spinning. i've tested the spin and it spins freely, water runs through the holes freely, i took out the volute cover and the check ball is clean and debris free. ...
it seems like you had a lot of service,,what i need you to do is check your drain hose,,make sure your drain hose goes up the height of the unit before it drains out,,if the water is laying in the drain hose it cant be use for the top spray arm....also the water in dishwasher at fill should be rite under heater element try and listen for slow fill ,,good luck repost if needed
Sep 08, 2011 | Dishwashers
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
I pulled the wiper arm up to clean under it and now I cannot get the wiper arm to go back to the down position. I understand it's probably something simple.
first remove wiper arm again and ignition on then switch on wiper without arm, let it run few second and switch off wiper wait few second and switch off ignition, now it has come to the rest position so you have to install wiper arm at rest position. don't let it to move when you tight it hold it by hand, I think this information be help you if you think right way what i mean. is this information helped you?
Oct 31, 2010 | Mercedes-Benz E320 Cars & Trucks
I cannot manually move forearm it keeps going back to resting place
Try adjusting the weight on the back of the tonearm. If it's too light the tonearm will just glide back to it's starting point.
Jan 13, 2010 | ION Audio iTTUSB Turntable
How do i get the tab out to tighten the wiper arm ?
I assume that you are speaking of the pivot arm. If I have this wrong please let me know so that I can provide the proper diagram. You have to lift the wiper arm off the windshield and pry the small tab in the diagram aside and let the tension on the wiper arm hold it aside. Here is a link to the pivot arm diagram ~ http://s219.photobucket.com/albums/cc270/anubiscycle/?action=view&current=wiperpivot.jpg
Jun 06, 2009 | 1999 Ford Crown Victoria
Power door lock switch replacement
Remove or Disconnect
Door handle trim plate.
  1. .Install or Connect
  2. Electrical connector and door lock cable.
  3. Trim panel by engaging hooks on backside of panel.
  4. Push pin fastener in defroster duct.
  5. Screw from behind lamp assembly.
  6. Courtesy lamp assembly.
  7. Two screws in arm rest.
  8. Arm rest cover plate.
  9. Door handle trim plate.
There May Be A Need to Drill Out RIVETS that Hold Motor in place,. Just Replace with>>MACHINED SCREWS & BOLT'S
  1. Trim panel. See: Doors, Hood and Trunk\Doors
  2. Four tabs retaining switch.
  3. Electrical connector.
Install or Connect
  1. Electrical connector.
  2. Snap switch into trim panel.
  3. Trim panel.
Mar 14, 2009 | 2000 Buick Park Avenue
I have a Dell 1720 and the output sensor light keeps blinking. I have read some of the solutions but would like to actually fix it instead of using tape and a quarter since it is for a customer. thanks
I assume that the solutions are telling you to make sure that the output tray has both of the tabs pushed down. There was an issue with these printers in the beginning with the tabs not going back down after being pushed up. On one of my printers, I removed the tab that was getting stuck and it seemed to do the trick.
Jan 28, 2009 | Dell 1720dn Laser Printer
Car window wipers are messed up
Take the cap covers off where the bottom of the wiper is. Lossen both bolts and adjust freely to where you want it then tighnen them up.
Jul 11, 2008 | 2000 Buick Century
Evenflo Generations Logo
Top Evenflo Baby Gear Experts
Barb
john h
ADMIN Canada
ADMIN Canada
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
