There are 2 ways to setup Netgear
1. Setup Wizard (which guides you through a setup wizard)
2. Manual Configuration (you need to put all values in router manually)
Here we are not discussing Setup Wizard as Manual configuration is far much easier then auto configuration
To configure (config) Netgear we need to get into router page
To open router config page
1. Open Internet Explorer (Start>>all prog>>Internet Explorer)
2. Type in address bar 192.168.0.1
3. In username box type admin (where it says gateway 192.168.0.1 requires username & password)
4. In password box type password (word password itself)
After this you will find Netgear ADSL Wireless Router Setup page
Here we need to select Basic Settings (as shown below)
after this you will find next page as
Here in this page (Basic Settings Page)
Does your internet connection requires login, Select Yes
Select Encapculation as PPPoE
Login is Username as provided by your ISP
Password is your password for broadband connection as provided by your ISP
Keep Idle timeout as 0
after this simply press apply without changing anything else
Now We Neehow to install and will this box allow my - adslsettings.jpgSL Settings Page
how to install and will this box allow my - adslsettingsscreen.jpg ADSL Setting Page We got only 3 options
Multiplexing Method Should be LLC-Based
VPI 0
VCI 35
now just press apply again
By this time your router should be only (you can check it by opening
any website on Internet Explorer or by router status option on netgear
page)
Click on Wireless Option (on left hand side blue panel)
It should display next page as
Here in this page
Wireless Network Name (SSID) Alpha-Numeric name which would be displayed as your wireless network name
Region Here Select Your Region
Channel: Select whichever channel give you best sighal (9, 11, 13 are recommended)
Keep the TIck on Enable Wireless Access Point
Keep the Tick on Allow Broadcast of Name (SSID)
Can Untick Wireless Isolation
Then Jump to Security Options
Select WPA-PSK (Wi-Fi Protected Access Pre Shared Key)
then in WPA-PSK Security Encryption type in anything of your own choice
but alphabets and numbers both should be there and make it between 8 to
63 characters long.
WPA-PSK Security Encryption Key is your password for wireless network
Now Press Apply and your router is ready for wireless too
MTU (Maximum Transmit Unit) size to 1400 from WAN Setup Option
You can find WAN Setup Option in how to install and will this box allow my - wansetupscreen.jpg left hand side of screen
Here you just need to change MTU to 1400 and need not to change any other setting
Now its all done and router is ready to send wireless signal to your system/laptop
