Question about Rival 18 Qt Roaster Oven with Buffet Server
Can I use my roaster oven ( model RO80) without the insert pan?
Posted by yulesee on
ellenskitche
    Sniper:
  • 62 Answers
It is possible, but not recommended as it is very difficult to clean. Did you know you can order a new insert pan on the Rival site? They are also occasionally available on EBay.
Posted on Nov 26, 2009
Do you add water to the bottom pan before you state cooking with it?
Yes, you need to add a couple of cups of water first... more depending on what you are cooking...if the meat you are cooking will make its own juice then you need not add any more...also if you are cooking at a higher temp then like 350 then you may need more water as it will boil off...
heatman101
Apr 23, 2011 | Rival 18 Qt Roaster Oven with Buffet...
The insert pan for my rival roaster is rusted?can i just put it in the roaster?
You can clean off the rust with a Brillo pad, You can also order a new insert pan; just be sure when you call that you have the model number for the roaster. Here is the phone number:
Rival® Customer Service
Phone:
1-800-557-4825
Nov 26, 2009 | Rival 18 Qt Roaster Oven with Buffet...
When roasting a turkey, do you use the insert or does the turkey go right in the oven
You definitely use the insert. Rival does not recommend using the roaster without the insert.
How do I cook a smoked ham in my rival elect. oven
Smithfield type country ham? Use the insert to soak it (I do two days in the fridge in skim milk made from nonfat dry milk), drain, add water and simmer in the roaster:
  • Bring water to 180 degrees (not quite simmering). Cook to 160 degrees internal temperature (or about 25 minutes per pound). Add water to keep ham covered.
  • Take ham from the pan and while warm, remove the skin carefully without tearing the fat. Dot the surface with cloves if desired, then sprinkle with brown sugar and bread crumbs
  • Drain roaster
  • Bake 15 minutes at 400 degrees (or long enough to brown nicely).
  • This makes the ham tender and not as salty as straight roasting.
    Do you put water in the botom pan
    No water between the roaster and the cooking pan!
    If using with the buffet server insert, put a couple inches in tn the cooking pan below the buffet pans.
    Here is the manual for additional help:
    http://www.rivalproducts.com/manuals/MANUALS/RO188BR_43_81844057.PDF
    Water between insert and roasting pan in Nesco electric roaster?
    Putting water BETWEEN THE BASE AND THE REMOVABLE PAN *is like putting water in your crock pot before inserting the porcelain dish and lid. This is dangerous and will destroy the unit. Those who answered "Yes" do not realize that the ? relates to putting water in the electric heating element portion of the pan... DANGEROUS!
    Sep 06, 2009 | Rival 18 Qt Roaster Oven with Buffet...
    Missing insert pan for Hamilton Beach Roaster oven model 527
    I am currently selling a triple buffet server by GE. It is new and in the box and says 'fits most 17 and 18 qt ovens. I bought it to use when I borrowed a roaster oven, but ended up never using it. It has 3 compartments, enamel on steel. It would take at least $11.00 to send and I would like $15.00 for the insert. If interested, answer this.
    Aug 10, 2009 | Rival 18 Qt Roaster Oven with Buffet...
    Missing insert pan
    call rival and tell them you need the replacement pan
    Dec 25, 2008 | Rival 18 Qt Roaster Oven with Buffet...
    Rival 18 Qt Roaster Oven with Buffet Server Logo
    629 people viewed this question
    Top Rival Kitchen Appliances - Others Experts
    Michael Thomas
    Michael Thomas
    Paul Carew
    Colin Stickland
    Colin Stickland
    Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
