Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
How do I find History on DVR & retrieve my protected recordings?
Posted by pjp56276 on
Anonymous
    Scholar:
    New Friend:
  • 24 Answers
In order to find your protected recording in the history on your DVR, you would simply press the button specifically labeled, "DVR" on your DISH Network remote, the DISH On Demand screen will then come on your tv, proceed by selecting "My recordings," on the "My Recordings" screen you will then select the "Sort" option. Once you have selected the sort option it will allow you to specify how you want the recordings sorted- the option you would want to select is, "Protected." I hope this helps you out, let me know if you need any other help! -Kirstie DISH Network
Posted on Jan 27, 2011
Panasonic SA HT1500 DVR recorder...cannot erase recorded programs.
On my DVR there is a "protect" option that will prevent me from deleting a recording. You have to press the "protect" button again to unprotect it.Once unprotected you should be able to delete the recording.
Dec 03, 2015 | Televison & Video
Cannot download video from dvr
DVR is meant to be used as playback device it's recorded information is stored in an encrypted form in the device. Even if the data is retrieved it might not be playable in another device.
Apr 18, 2014 | EverFocus ECOR264-9X1-1T - ECOR264x1...
I have accidently deleted my call history and i need to retrieve a number, is there a code to help me get my call history back for samsung c3050
Amanda, There is no way that you can retrieve the deleted data in the mobile phones.
Hwever, you can make a request to the service provider for your call records between the dates that you remember when that call came. They can give your call record for that period.
Jun 30, 2011 | Samsung Cell Phones
Since my comcast switched to digital I cant record !! Is this DVR compatiable with Comcast digital cable???
Yes,all DVR compatible with digital signal that included Comcast digital cable.U can't record because probally the program u tried to record it copy write protected.What did u tried to record?Just tried to record some plain show,If it is recordable than u know the deal.
Feb 02, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
DVR LOST ALL RECORDINGS (EVEN PROTECTED RECORDINGS), ALL HISTORY OF SEARCHES. TALKED WITH DISH & THEY HAVE NEVER HEARD OF SUCH A THING. RECORDED SEVERAL MORE PROGRAMS & IT DELETED THOSE AS...
Hello, Daniel Busa with Dish Network. If this is still persisting you may need a replacement give us a call or you can contact us on twitter and we will get it resolved.
Jun 28, 2010 | DISH Network ViP722 DTV Receiver /...
We keep losing shows! They record just fine, but then a few have disappeared, even when protected. Any ideas where they might be, and/or how to keep this from happening?
Check to see how full you DVR is. This happened to us and our DVR was filled up. When that happens the DVR starts to delete stuff, even protected things. It will first delete non-protected shows and then if there are none left to delete and room is still needed, it will delete other shows. Not sure, or can't remember how it prioritizes the deletion but it happens.
Check how full you DVR is and that may be where your problem lies.
Apr 23, 2010 | DISH Network DVR-625 DTV Receiver /...
My dish dvr "failed" & it has 60+ hours of important video;
proseity
If the receiver is leased from DISH Network, it specifies is the receiver is alter in any manner, the warranty is voided. If you own the receiver, you are free to do what you like with your receiver. I hope this helps.
Ray Calo
DISH Network
Apr 14, 2010 | DISH Network ViP622 DVR DTV Receiver /...
My DVD recorder LG RH1858 isn't recording properly. It shows the message "record blocking sidnal are detected". Please inform.
Unfortunately, your recorder is picking up a signal in the broadcast that copy-protects the show. The recorder is programmed to forbid copying of protected material. Depending on the source of the copy-protection, you may be able to block out the copy protection signal with a hardware filter. One example of these would be the Sima CT-2 that is placed between the S-out of the receiver and the S-in of the recorder.
I hope this helps.
(One common sources with this issue: a DVR that passes on the copy protection to an attached DVD recorder. Particularly some of the new Satellite/Cable receivers with built-in DVRs. The non-DVR models of the products usually filter out the copy-protection.)
Mar 29, 2010 | LG RH177 DVD Recorder/HDD Recorder
All protected & unprotected recordings lost - possibly moved to History. In My Recordings, one program was listed - a basketball game that we did not record. A day or two before these things happened,...
There are no history for your recordings, whatever shows up in your recording list is what you have. if this did this on its own then it sounds as if you have hard drive failure on your dvr and it will need to be replaced. Your protected events should never delete unless there is failure or deleted by a user.
Nov 26, 2009 | DISH Network ViP622 DVR DTV Receiver /...
I have mistakenly erased everything on my Sagem digibox hard disc - is there any way of retrieving this material?
Hi! I sorry to hear that you mistakenly erased everything from your sagem digibox hard disc. Im afraid there is no other way to retrieve everything that is in the hard disc. Bcoz the hard disc of you sagem digibox only depends on the software that is installed on the system in order to save and record. I have a dish dvr as well that can record and save dvr events, but once I delete the event, its gone forever..
please feel free to get in touch
Aug 31, 2009 | Televison & Video
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
505 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Sheldon Dedek
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
