Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
All protected & unprotected recordings lost - possibly moved to History. In My Recordings, one program was listed - a basketball game that we did not record. A day or two before these things happened, the titles were scrambled. I thought I'd fix it later but by then everything was gone, except the game, which I deleted. If these recordings are in History, how can I retrieve them?
Posted by pjp56276 on
Anonymous
    New Friend:
  • 56 Answers
There are no history for your recordings, whatever shows up in your recording list is what you have. if this did this on its own then it sounds as if you have hard drive failure on your dvr and it will need to be replaced. Your protected events should never delete unless there is failure or deleted by a user.
Posted on Nov 30, 2009
Panasonic SA HT1500 DVR recorder...cannot erase recorded programs.
On my DVR there is a "protect" option that will prevent me from deleting a recording. You have to press the "protect" button again to unprotect it.Once unprotected you should be able to delete the recording.
Dec 03, 2015 | Televison & Video
I can#t access the guideplus
Go to the hard disk setup menu.
Chose initiolized HDD, same as picture below.
Sometimes this can fix the problem.
Regarding the firmware, I do not think there is any firmware update available for download for this unit.
I did not find any download for your product.
Often, the image disk is distributed only to qualified repairers.
Sep 24, 2008 | Televison & Video
Recover deleted history
Hi there Janice, If you have a Hopper system and have deleted all of your recordings, you may recuperate them by pressing 'Menu' on your remote, selecting 'DVR' then 'My recordings' and 'Deleted Recordings' Once you are in the 'Deleted Recordings Screen' you have the option to select 'Restore' (this option will allow you to restore all Deleted Recordings) Unfortunately no other receiver has the capacity to restore deleted recordings.
Kimberly Escobar
Social Media Representative
DISH L.L.C
Feb 02, 2014 | DISH Network Televison & Video
Bauhn Manual for APVR-9650T
http://forums.whirlpool.net.au/archive/2211037
Quoting from above:
Bauhn 1TB PVR
model APVR-9650T
a REVIEW
Spent a couple of hours with this PVR, comparing it with an earlier model Bauhn 1TB PVR (AS-PVR1000R, 2011).
Bought on sale Wednesday, $199.
[Only commented on differences between models. Have previously reviewed the older model - which still is a reasonably good PVR.]
Summary: not bad, some good features in a budget PVR, and a couple of annoying issues that weren't in older models (which should be easy to fix in firmware). Works well, responsive remote, although I prefer the button press of earlier model.
But product quality control is worryingly patchy. Bought 2 units, 1 was dead out of box!! Confirms my advice to buy 2 to get 1 that works well. (On power up with good broadcast signal, TV displayed Bauhn logo for few seconds, then blank screen, sound of HDD, and never advanced past "----" on PVR. Tried many times on different video outputs & TVs.)
I'll probably be returning this PVR within 60 days as the few annoying aspects outweigh the added features for my needs, over my older BAUHN PVR.
Features:
Series Record:
Records all programs with that title on that network. (Still assessing if SERIES RECORDs program on more than 1 network - e.g. records Simpsons on 10 & 11, but does it SERIES RECORD Mythbusters on SBS, as well as 7Mate?)
Good if you are away from PVR as it changes recording times to latest EPG (as long as broadcast sticks to EPG times), if program schedule frequently changes, and does not record if program is dropped from schedule.
(I have returned from overseas to find what I had set to record was not what was recorded as the program line-up had changed. SERIES RECORD should solve that.)
But... takes up many available recording schedules including ones you may not want recorded (PVR has maximum of 50 TIMER schedules, so for example SERIES RECORD "QI" on ABC1 - with 13 episodes/wk, would occupy over ¼ of available schedules!).
Also you cannot pad these recordings - adding a few minutes before/ after in case program starts early/ ends late. Changed recording time may conflict with other recording schedules meaning program may not record (check by EPG Search). Takes some getting used to to ensure consistent recordings.
Setting up standard weekly etc TIMERS may be preferable & more predictable.
EPG Search:
Searches for all programs by title within 7 day EPG, on all channels. Shows & allows setup of recording schedule, and if there are conflicts between SERIES RECORD & recordings, to set Priority.
Scheduled Recordings from EPG:
Settings for recording Once, Daily, Weekly, Weekday/ Weekend.
You can pad scheduled EPG recording times by up to only 10 minutes, in case program airs early/late.
(The older 1000 model can pad up to many hours - e.g. to record multiple consecutive shows on 1 recording, and the recording date can be changed to skip that particular recording. You can manually set up recordings to achieve this on this PVR, but then lacks program name, which you can rename. An advantage if you are running out of schedule recording slots.)
Time Shift:
Up to 2 hours, which is adequate. Can set to always be on, so can pause/rewind live programs when you wish. (1000 model can be set to almost limitless Time Shift. Mine is set to 4 hours.)
Editing Recordings:
Editing would suggest removing unwanted sections, but this PVR simply marks sections of the recording for viewing, skipping the unwanted. The file remains the same size, and copying the file to another device leaves the original unedited recording.
Settings:
MENU-PVR Settings: (handy when setting up)
Set Time Shift length (30-120 min) + Time Shift Function (Disable / Enable)
Playback Start Position (Beginning of program / Continuing from where you were watching) Continuing is handy.
Auto Play Next Program (Disable - stops playing at end at end of recording / Enable to watch recording then next recording )
MENU-Settings:
Audio&Video Output Settings
(set to suit your TV etc)
Time (by State & Daylight Saving - otherwise EPG & recording time will be incorrect)
Channel List (press OK during live TV):
Can delete unwanted channels (which the 1000 model annoying could not).
Can set up 1 set of Favourite channels
External USB Storage:
2 USB (1 front, 1 rear) capable of accessing larger HDD (tried with 3TB) formatted as NTFS or FAT32. So quite useful, as I found on 1000 model.
Copying is painfully slow. On 1000 model, crashes occurred when storage for recordings was set to a USB device (MENU-PVR-PVR Setting-Recording Storage) - don't do it!
USB drives less than 16GB can't be formatted on PVR.
WARNING: If PVR freezes (too high load on processor like copying too much or Copying + Recording) while writing to external HDD, HDD may be corrupted when you are forced to unplug PVR from power! (Have had Seagate HDD totally corrupted twice with 1000 model - files cannot be recovered due to storage method). Best not to copy too much at time to HDD!
Networking: (Not assessed yet)
Via Ethernet cable. Can access recordings, photos, music on PC, and transfer to PC from PVR. Access is typically MUCH faster than to USB storage. But requires files to be in set folder, which may be unsuitable.
Media Player (Not assessed yet)
Photo & Music Players have been added . Playing MP4 files is not great.
Annoying aspects...
OSD can't be hidden when using Pause
Pausing live program, or recording leaves an information box on screen - there is no way to remove it. Pausing a recording is something I regularly do, to view details. The PAUSE bar includes the EDITING tools, making it larger than normal. As the on-screen-display covers nearly 20% of the screen, at the bottom, subtitles and information bars broadcast with the program can't be seen! You can only increase the Transparency, meaning you can see through the OSD (MENU-Settings-PVR Setting 1-60%). However, setting a high level of Transparency makes using any OSD difficult.
Slow boot time
It takes about 35 seconds to.power up from Standby to fully operational. While that is marginally faster than the older 1000 model, it is slow.
Slow navigation within EPG, Timer & Media Browser etc
There are no P+/P- (Page up/down) buttons as on 1000 model. Moving up/down a list to select between possibly hundreds of programs (recordings) is SO slow - moving 1 at a time instead of a page at a time. (Strangely the P+/P- can still be found in the onscreen keyboard when you Rename recordings or do an EPG Search. There it performs a keyboard shift function.)
Slow navigation within Recordings & Time Shift TV
FF/REW speed is a maximum of 32X, against 64X on 1000 model.
There is a very handy undocumented feature of FF/REW by holding down the right/left arrows - located around the circular OK button (while watching your time position on the progress bar). Handy for moving quickly to position in program or skipping ads. (I found this on the earlier 500 & 1000 models.) However it is SO much slower to FF/REW on this model.
Bright Standby light
As in the older model, the very bright blue light can be annoying, but easily fixed with a small piece of black electrical tape or similar.
PVRs take time to discover their flaws & features, so I'll keep exploring ;-)
Aug 10, 2013 | Cell Phones
What is the best way to remove protection from TiVo videos?
Yes, TIVO recordings store the video using MPEG-2 compression and include copyright protection. To retain its intact video quality, you can use a copy-protection removal program. In this way, protection is removed and the original video will be kept to be compatible with common media player. The program I recommend is Pavtube Video Converter which provides "Directly copy" option. Just input your TIVO access key, choose directly copy and you will get copy-free MPEG 2 video with extreme speed. I bought this program mainly to convert recorded TIVO videos for my iPad 3. This program provides presets for ipad. The output videos play perfectly in my iPad. http://www.pavtube.com/video_converter/
Jun 11, 2012 | Audio Players & Recorders
Cannot get the recorder to record on a blank cd. The message received states the cd is protected. I have the unprotected choice checked.
This is a comercial DVD like movies or events?Yes,than it have copyright protected codes inside it programing.Just check unprotected,will do nothing.Most of these DVD discs must run through a computer programing for decoding,before u can made a duplication.
Feb 17, 2011 | Televison & Video
I accidentally deleted a recording... how do I recover this recording?
It is possible to recover your lost recordings.
First things first: DO NOT take any more recordings with the memory card that you want to recover records from in case you may quite possibly ruin your chances of recovery.
Then Connect the card to your computer as it should appear as a "Removable Drive" or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a data recovery utility that will recover your recordings with Wondershare Recovery Software from the following link:
Video Photo Recovery (if you are running Windows OS)
Mac Data Recovery (from MacUpdate site)
Do NOT try & write anything back to your card until you can recover your recordings safely!
Oct 26, 2010 | SanDisk Sansa e250 MP3 Player
DVR LOST ALL RECORDINGS (EVEN PROTECTED RECORDINGS), ALL HISTORY OF SEARCHES. TALKED WITH DISH & THEY HAVE NEVER HEARD OF SUCH A THING. RECORDED SEVERAL MORE PROGRAMS & IT DELETED THOSE AS...
Hello, Daniel Busa with Dish Network. If this is still persisting you may need a replacement give us a call or you can contact us on twitter and we will get it resolved.
Jun 28, 2010 | DISH Network ViP722 DTV Receiver /...
How do I find History on DVR & retrieve my protected recordings?
In order to find your protected recording in the history on your DVR, you would simply press the button specifically labeled, "DVR" on your DISH Network remote, the DISH On Demand screen will then come on your tv, proceed by selecting "My recordings," on the "My Recordings" screen you will then select the "Sort" option. Once you have selected the sort option it will allow you to specify how you want the recordings sorted- the option you would want to select is, "Protected." I hope this helps you out, let me know if you need any other help! -Kirstie DISH Network
Nov 26, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Panasonic DVDR-EX77EB all of the channels say NO SERVICE
Full reset/factory reset will remove your record schedule but not your recordings.
Recordings are possibly lost when replacing the software for updated versions.
Dec 21, 2017 | Panasonic DMR-EH57 HDD Recorder Player
Open Questions:
Dish 722 not acquiring signal on boot up. must disconnect antenna cable and reconnet then works fine. Dish Tech support is useless and my contract is up in 1 month, so I am considering canceling. Any This problem began about 6 months ago. Nothing unusual happened that I am aware of. When the system is first booted, it will stay on the acquiring satellite screen with no progress and ultimately fail. If I disconnect the antenna (LNB) cable and reconnect then it immediately shows progress and acquires the satellites and works fine until it is shut off and restarted again. Dish Tech support is useless, no they are LESS then useless. I have tried replacing the antenna dish and lnb, running new cable from antenna to receiver, replaced the splitter switch (for 1 and 2) all with no success, so I have concluded this issue must be with the 722 receiver itself. As I mentioned I have made 3 attempts to get help from dish with no success ("maybe there are clouds in the way every time you boot the receiver and they happen to disappear just when you disconnect and reconnect the cable" <<< No I am not kidding). I thought it might be a grounding issue so I ran a separate ground directly to the antenna dish with no success. SInce the 1000.2 antenna does not require a seperate switch, I have tried connecting the LNB cable to each of the 4 inputs on the LNB with the same result on each. We live in Florida so we shut the receiver off when we are not home to reduce the danger of lightning damage, consequently this problem becomes an irritant on a daily basis. Any ideas? My contract with dish ends in 1 month so if I cannot fix this, I am most likely going to switch to cable or directtv. Except for this problem the unit works properly as does the dvr.
Feb 28, 2017 | DISH Network ViP622 DVR DTV Receiver /...
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
775 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Sheldon Dedek
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
