I don't know how much experience in working on stuff like this, but it sounds like a solder run might be cracked. If you're lucky, it might be that a gang plug needs to be "exercised" by pulling off and the replacing a couple of times. You might want to try to do this - anyone with a modicum of experience in working on electronics and computers will be able to pull this off. Chances are, you'll disturb the connection to either get it to work, or to make it worse. If worse, that is actually better, as intermittent problems are expensive to have fixed.
Testimonial: "Thank you. I believe you gave me a good direction to follow up on. If this does not work I may part out the unit on ebay. "
