Question about Samsung RS2630SH Side by Side Refrigerator
Please help. I have a Samsung RS2555SL Refrigerator, and the ice make won't make ice. The ice tray remains turned over as if it is dumping ice. When I push the Test Button on the ice maker, the tray turns over, then turns back over to it's original upside down position. While it is returning to upside down, and a popping noise occurs. Then water is dispensed on the upside down tray, spilling water into the freezer. Appreciate any help on this.
Posted by clauderblake on
John Tripp
  • Samsung Master
  • 4,656 Answers
I will assist you with your ice maker problems if you like, Thanks Sea Breeze
Posted on Nov 26, 2009
  • John Tripp
    John Tripp Nov 26, 2009
    First is the link to the service manual HERE=> RS2555SL Next is a link to Service Bulletin=> HERE and a link to my sites and Forum here
    SEA BREEZE APPLIANCE PARTS AND TECHNICAL SERVICES
    Please ask any questions here or through my free Forum and I will assist you and help you resolve the problems you are having, Thank you, Sea Breeze
  • John Tripp
    Here is another Service Bulletin related to your model HERE Please let me know when ready, Sea Breeze
Whirlpool ice maker quit.
If it's similar to my Samsung, mine did the same. There is a reset button at the front of the box which contains the ice cube tray. If you press it, the ice tray rotates to dump the cubes, then refills. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
Ice maker on whirlpool quit working .
If it's like my Samsung, there is a reset micro switch button in front of the box containing the ice cube tray. Press it and the machine resets, the ice cube tray rotates, dumping the cubes. It then rights itself and fills with water. Hope this helps.
Ice maker makes ice but does not dump
The mechanism (motor) in the tray housing is bad. Trying to manually turn the tray to dump the ice can actually do the harm to the motor. Not advised. You'll need to buy a new Tray Assembly.
Jan 07, 2015 | Samsung RS2534 Side by Side Refrigerator
Ice maker not dumping ice.
sounds like the icemaker timing or motor is bad. those parts are not replaceable on this model, you would need a new icemaker assembly
May 02, 2012 | Samsung Refrigerators
Samsung Refrigerator makes ice, but then quits.
I have this same thing happening, also. I have not been able to find a solution to this issue, however. The ejector blades push against the ice, apparently a gear pops loose with a loud clicking sound and the heater either does not work or never turns on. I end up killing the breaker to thr refrig,`removing the icemaker, letting it wrm up dumping the ice and putting it back in.
Aug 21, 2009 | Samsung RF265AA Bottom Freezer French Door...
Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
Mar 31, 2009 | Samsung RS2578BB Side by Side Refrigerator
Samsang rs2555sl Ice maker
Call Samsung and get a straight answer.
Dec 21, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
Jan 02, 2007 | Samsung RS2578BB Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
613 people viewed this question
Top Samsung Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
