There is a main motor lock caused by the duplex motor area. Turn off and wait for 30 sec then on , if no change clean the duplex motor's sensor.There is a main motor lock caused by the duplex motor area. Turn off and wait for 30 sec then on , if no change clean the duplex motor's sensor.
You can't post conmments that contain an email address.
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
The thermistor inside of the fuser needs to be reset before you can clear the code. If you remove the top cover of the fuser the thermistor is located on top of the upper fusser roller. It should be reset able by pushing in. Then you put in the reset code. you may want a tech to look into what caused this.
This mean you have low temp. on heat lamp 2 program interput clear interrupt 14 print may clear this code. if not you can look at the fusing unit and reset thrmo breaker that may be pop off.
F2 usually means its a component failure that should be looked at by a technician. You could trying turning it off wait 30 seconds and turn it back on again to see if it goes away.
Make sure there is no paper jammed in machine, H5-01 means 5 jams same location. Use quality paper not recycled and make sure it is fresh not old stock
PROGRAM INTERUPT CLEAR INTERRUPT must be SUPER FAST then 14....WILL RESET CODE
