My Kodak m1063 gets a pink sky in the background,I can adjust the lighting setting and it helps some but it goes right back to the same on the next picture,so I can't take a picture rihgt after each without readjusting.Indoors I don't have that problem unless there is a very bright light in the background.
It sounds like your white-balance is off on the magenta side of things. This could be caused by a number of factors, though I would explore your camera's white balance setting to make sure it's set for the right lighting situation. If changing your white balance setting fails, it may be a more serious issue with your sensor or other camera hardware, requiring a professional to repair it.
Is this in all the SCN?
I'm sorry, but in this case there isn't much more to do than to Trade up. Since this model is no longer repaired due to spare parts shortage.
When this happens the voltages on some of the circuit boards can be adjusted to claer up this problem. THIS IS NOT some thing a person should do them self, the voltages are dangerous and critical to the operation of the set. "This should only be done by a trained service technician."
Using the on screen menu, check the hue or wall color settings.
[Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
First, plug a external monitor and toggle the screen to discard configuration or software problems. If the image displays correctly you have a problem either in the LCD screen or its connection cable.
Open the bezel and check for loose or damaged connection cable. Look specially next to the hinge, ON THE LEFT.
In case the problem is not the cable you might have to get a new LCD. You can have replacement parts and instructions here:
Sane problem with C713, the view screen is dark and gives focus warning, then the pics come out with a pink tint. I believe it is the sensor or shutter problem. Can't get any solutions either.
