Question about Maytag MZD2766GES Side by Side Refrigerator
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Maytag side-by-side refrigerator model #MZD2766GE approx. 7 years old, freezer functioning well keeping food frozen and making ice, refrigerator portion not cooling well. Have cooling level up to 9 and it barely has food cold.
Posted by dwel387 on
D. Floyd Kolb
  • Maytag Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Posted on Sep 30, 2010
Maytag side by side refrigerator - refrigerator and freezer both not cooling.
I had same issue , required a new compressor and regas. All cooling for fridge side is blown in from freezer
Jan 25, 2013 | Maytag Refrigerators
Hello, Problem with Maytag plus Side by Side refrigerator model MZD2766GE.The Freezer part is working fine but the fridge part is not cold at all even after I adjusted the temperature to number 8. I do not...
You most likely have a defrost heater and/or defrost term switch. (switch is built into heater on your fridge).that needs replaced causing your coil to completely freeze up and blocking cool air flow to fridge side. Here is the part you need to order.
http://www.appliancepartspros.com/part_details.aspx?part_id=4069923
Thanks, Randy
Feb 07, 2011 | Maytag MZD2766G Side by Side Refrigerator
Maytag MZD2766GE refrigerator side is not cooling well. Freezer side has no problem. Where are the coils for cleaning? Any other ideas?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Dec 31, 2010 | Maytag MZD2766GES Side by Side...
Refrigerator side doesn't feel cool but the freezer side is cold for a Maytag refrigerator model # MZD2766GE
Is there ice build-up in the back of the freezer? If so take the panel off the back of the freezer section inside the freezer and replace the heating element.
Jul 21, 2010 | Maytag MZD2766GES Side by Side...
Maytag side by side not getting cold enough
look in the back should have a fan in the bottom probably very dusty if it is it cant cool fridge clean it and it should work unplug it to clean
Jun 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
Mar 08, 2009 | Maytag MZD2766GES Side by Side...
MAYTAG MZD2766GE SIDE BY SIDE
Mine kept doing the same thing- the flap between the freezer & the frig is getting stuck. I finally just broke mine off & left it that way. Now the frig is really cold, sometimes things partially freeze- but that is better than going rotten. I now have a section under the water/ice dispense tray bubbling/peeling the white paint off. Mine is 6.5 years old & out of warranty, so I'm searching for a way to repair this problem. Any suggestions?
Jul 11, 2007 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
gbob59
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
