Your copy lamp is faulty or scanner drive is not moving. Check the lamp and replace if not lighting.
If its the scanner, unlock the scanner lock above the paper exit tray.
Posted on Dec 15, 2009
When scanner unite was dirty,all sensor dirty or scanner position lock.please clean all surface ,unlock position.
Posted on Dec 19, 2009
SOURCE: Sharp AL-1631
try this. Press C (cancel), Press Auto, Press C, press Auto
Enter 14 (code) e Press Print (green)
It´s a code to cancel H4, if it´s don´t work, send me e-mail to [email protected]
Posted on Feb 15, 2008
SOURCE: error code on display, L1 or 1L flashing. What is
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Posted on Jul 16, 2010
SOURCE: Flashing L1 Display
L1:Indicates that the Main PWB sensed that the carriage did not leave home after power up or after start is pressed
You may have a bad scan motor, Fuses do blow on those.
Also check for the lamp carriage binding on something.
But as the fault states, the machine is not seeing the lamp moving forward .
Posted on Jan 09, 2008
SOURCE: H3 ERROR CODE SHARP AL 1631
H3:
00:TEMPERATURE OF FUSER UNIT HIGH,THERMISTOR CONTROL BOARD FAILING
Did you replace the thermistor? check the thermofuse also for continuity
Posted on Oct 20, 2008
SOURCE: sharp al-1631 copier. drum error code
You can reset this indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
Posted on Nov 16, 2009
Testimonial: "Ok sorry thank u. I am new sorry i will be better in the future."
Dec 07, 2015 | Sharp AL-1631 Digital Laser Copier
Oct 23, 2013 | Sharp AL-1631 Digital Laser Copier
Feb 09, 2011 | Sharp AL 1631 Copier
Aug 03, 2010 | Sharp AL 1631 Copier
Jul 15, 2010 | Sharp AL 1631 Copier
May 24, 2010 | Sharp AL 1631 Copier
Aug 09, 2009 | Sharp AL 1631 Copier
Jul 06, 2009 | Sharp AL 1631 Copier
Dec 26, 2007 | Sharp AL 1631 Copier
Jun 12, 2014 | Sharp AL 1631 Copier
Mar 17, 2014 | Sharp AL 1631 Copier
2,231 people viewed this question
L1 has two meanings a. Copy lamp not lighting. Check it and replace if faulty. b. Scanner is locked. Unlock from the lock lever on top of exit tray or manually move the scanner and check where it is jamming.
