Log in to your NETGEAR router by browsing to
http://www.routerlogin.net/ or
http://www.routerlogin.com./ Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
If you cannot log into your router: Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults.
However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings. If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection.
Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and Clicking
Apply. If there is a small hole in the front or back of the router push a hair pin in to reset to factory settings.
