Unless you had your tonearm replaced previously, perhaps the technician did not route the cables correctly through the tonearm base. If so, then this would explain why it works after you raised the tonearm height.
If not, then consider yourself lucky that you didn't have to replace the tonearm. Often times, replacing the RCA cables correct the problem. However, if it does not, the next step is to replace the tonearm. And if neither works, your issue is with your cartridge or headshell (which you should have checked first). Or sometimes, the work was not done correctly when the RCA or Tonearm was replaced - so make sure you use a reputable service tech for this. If you are going to do this yourself, make sure you triple check your work.
TWEAK A/V LAB
