Sanyo HT32744 32" TV Logo
Posted on Nov 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Green Screen on an HDTV
My Sanyo HT32744 32" hdtv is having color problems; it seems to be fading to green. Is there any way to fix it without knowing about TVs, or better to go buy new?
Anthony Butcher
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Mar 05, 2010
Anthony Butcher
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
Helped
10393
Points
19
I too had the same problem where my HT30744 TV would lose its color. My mom's HT32744 would have the same problem too. They both are refurbished models bought at Value City Dept store. If I gave the cabinet a good hit it would mostly fix the color, but it could also make the picture go fuzzy too, a clear sign of just a loose connection somewhere.
So after my wife telling me she was sick of this almost 2 year problem and she was going to buy a new TV on the weekend, I figured I had nothing to lose. So I took the rear cabinet off, unseated the card mounted on the picture tube, applied a little dielectric grease on the connector on the card and reseated the card, removed, re-greased and reattached the card. I have had no problem with either my or mom's which I did the same to since! This is an easy fix that anyone can do. The hardest part is moving the TV and reassembling the rear cabinet. Do not pull the cabinet back out more than you have to, to ease the reassembly of it.
Anonymous
Level 2:
Scholar:
  • Expert 63 Answers
  • Posted on Nov 25, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
63
Questions
0
Helped
11991
Points
195
I do not believe there is any easy fix to this. The problem may be either in the picture tube or the related circuitry. The worst case scenario is the tube itself is failing. However, it could be as simple as a defective connection on the pc board at the tube for example. You may want to get a technician to check it out and get an estimate before you buy a new set. Good luck
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 12, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
648
Points
I have the same problem with mine. This may sound strange, but I placed a fan along the side of the tv, I have had no problems since. I believe this may be a heat related problem.
Green and blue faded
Some of these had bad picture tubes--(model indicated here uses 3 tubes)
Simple test is go to a black and white channel and turn color to zero= is the screen black and white or some other color?
Also go to a unused video input and look at screen=all you should see is black screen with the input number in green= any other color and something may just need to be adjusted.
I have a Niko LCD HDTV model OTP-3211W after a...
I'm having the same issue. Any luck wtih resolving this issue?
The color has faded . I replaced the bulb the problem persists!
Light Engine is Bad, If you had said TV was making loud whistling sound then it would be Bad color Wheel
3helpful
KP-65WV700 Red and Green Lamps fade out after about 15 seconds
If you know how to adjust G2 (screen) volt adjustment then increase a little bit screen volts of red and green lamp.
Scrolling Green color on screen
If the lines are like pin stripes going from left to right then you most likely have a defective green crt
Green color screen
your hdtv cables are wrong color match them to the input on tv
Green color
Hi...this could be the colorwheel. Very common in this model and an easy fix too.
2answers
Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on [email protected]
Color fade
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Flashing Green
I would guess that your problem is similiar to mine but mine is with the color red. The CRT went out which is a 400 dollar part and who knows how hard to fix.
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
