Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Need to unlock cooktop lockout - Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Posted by l7m7w7 on
Anonymous
    New Friend:
How to unlock cooktop of kinmore oven
Posted on Apr 05, 2010
Error 40 on kenmore convection oven
The 40 error code indicates a failure of the cooktop lockout board. The cooktop lockout board is not communicating with the main EOC electronic oven control. This could be a loose wiring harness or either the EOC board or cooktop lockout board is faulty. This type of diagnosis will require using a volt/ohm meter. If you decide to check the harness to the boards you will need to remove the back panel for access.
Oct 15, 2017 | Kenmore Ovens
I cannot unlock the cooktop on my Kenmore gas range. There is no lockout button, only Select Clean and Stop/Clear. Neither one of which unlocked the cooktop. There is a little padlock looking symbol t
I'm sorry, but the model number given in the question is either wrong or incomplete. Please check that model number. Usually, on Kenmore ranges, you can find the model # and serial # on either the left or right side of the storage or warmer drawer. Open the drawer and look on the frame of the range for a label. On a few ranges, the label is affixed to the frame between the oven door and the drawer.
As an alternative, please post a clear picture of the control panel.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 20, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Managemylife com
From the manual:
To turn the Cooktop Lockout Feature OFF:
1. Press and hold (_ until "CLO" appears (Figure 3). Continue holding
until a second beep sounds (after 3 seconds). I_1will disappear from
the display indicating the cooktop may be used normally (Figure 4).
Note: Starting a Self-Clean cycle will automatically turn ON the Cooktop
Lockout feature. The cooktop will remain locked until the Self-Clean cycle
has completed and the oven door has unlocked. If a power failure occurs
after the Cooktop Lockout has been activated, you must turn OFF the
Cooktop Lockout feature before being able to use the cooktop features
again.
Dec 14, 2013 | Stoves Kitchen Ranges
How do I fix an F40 code on a kenmore elite rlectric range model #790.46709603
The "F40" fault code indicates a Cooktop Lockout error. There is a "Lockout" control board that locks out the cooktop from operating whenever the "Clean" cycle is used. It's not normal to display "F40" unless there is a "Lockout" or an "EOC" (electronic oven control) failure. It may need one or the other or both boards replaced. If the cooktop will operate after the range has cooled and unlocked then it may need the EOC and not the Lockout board. If you can ignore the beeping and the F40 and the range will heat up again in the clean cycle and complete the clean cycle then it could have a faulty Lockout board. Here a link to a YouTube video with the instructions on how to access and replace the EOC.
Here is the lockout board if you need to order it.
Here is the EOC board if you should need it also.
All parts come with a 365 day, any part, any reason return policy.
Apr 06, 2013 | Kitchen Ranges
Electric range surface elements not working after self clean cycle.
It sounds like it is broken. You can bypass it by connecting the 2 wires together. This should be fine until you replace it. They aren't that expensive.
Mar 06, 2013 | GE Ovens
HOW TO UNLOCK JEN-AIR STOVE TOP MODEL# JED4536WR01
The All Off cooktop touch control turns off the downdraft exhaust
system and all surface cooking areas that are in use at the same
time.
The Lock cooktop control avoids unintended use of the surface
cooking areas. When the cooktop is locked out, the surface
cooking areas cannot be turned on by the cooktop touch
controls.
To Lock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds. After 4 seconds, ALL OFF/LOCK will glow red,
indicating that the cooktop controls are in the lockout position.
To Unlock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds.
Apr 24, 2011 | Microwave Ovens
After self- cleaning my Kenmore Gas Range, I have not been able to get the 'Cooktop Lock' light turned off! So while I can use my oven for baking I can't turn the gas on the top of my stove! I have...
This may be a silly question but, did you just try turning off the circuit breaker for a couple minutes to see if it resets itself when you flip it back on?
Nov 21, 2010 | Kenmore Kitchen Ranges
Need to unlock the controls of my Whirlpool gas oven
To Lock Or Unlock Cooktop
1. Turn all control knobs to OFF.
2. Press and hold the Cooktop Lockout icon keypad for 3 seconds. A single tone will
sound, and “Loc On” and a cooktop icon will appear on the display. After 3 sec-
onds the clock display will reappear.
3. Repeat steps 1 and 2 to unlock cooktop. “Loc OFF” will appear on the display for
3 seconds, and the cooktop icon will disappear from the display.
Feb 13, 2008 | Whirlpool SF367 Gas Kitchen Range
Our cooktop will not turn on!!
Plug the power line press the reset button.
Jan 03, 2008 | KitchenAid 32 in. KECC508 Electric Cooktop
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
650 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
