Central heat won't turn off instantly.
I have central heat and after I turn off the heater with the switch on the Honeywell panel the heater does not turn off instantly. Sometimes it take 10 minutes to turn off. Is this normal?
Posted by martinghatta on
Anonymous
    New Friend:
  • 161 Answers
Yes it is normal. the blower continues to run after the heat turns off to cool the system down.
Posted on Nov 25, 2009
I have Drayton Heating System in new home. I seem to be unable to put my central heating on without also having the water heater on. The boiler will come on if the water heating and central heating is on...
you will only be able to have the central heating on seperately if the system is fully pumped. Why would you not want the water to heat? it is more cost effective to use the residual heat to heat the water and keep the temperature up. Costs alot more to heat a cold house and a cold water tank
Nov 06, 2011 | Honeywell Programmable Thermostat Heater
I need programming info for an Altech model ALTHC001 central heating and hot water programmer
Can you please tell me how to set clock for central heating the clock is an althc001 had power switch off and when it was turn back on the clock is not working when the boiler is calling for heat and the same with the heating can you help
Oct 07, 2011 | Honeywell Programmable Thermostat Heater
Programmable Thermostat Heater: no power to honeywell central heating control...
Multiple possibilities:
Damage to cable (doing any DIY?)
Failure of thermo
Board gone in heat unit
Possibly simple as loose or disengaged connection, check at thermo & heat unit, if nothing obvious, call serviceperson.
May 18, 2010 | Honeywell Programmable Thermostat Heater
My ACL lifestyle lp522 doesnt turn heater off
Hi it sounds like it hs worn inside exchaning it would be the cheaper option
Feb 01, 2010 | Honeywell Programmable Thermostat Heater
I am attempting to turn on the home central gas heater for the first time this year. It is controlled by a honeywell self ignition model number sv9541. I follow the instructions on the front panel and...
Check to make sure the gas valve is opened. I've turned mine off for the summer months; when I went to use the heater for the first time...I realized I had turned the gas off.
Nov 17, 2009 | Honeywell Programmable Thermostat Heater
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
Central honeywell air conditioner
Sounds like it may have lost power. Check the breaker and the fuse at the furnace. If they are all in the on position and working then it sounds like you may need a technician. If the display is blank on the thermostat you may also want to replace the batteries.
Jun 12, 2008 | Honeywell Electronic Programmable...
Central heating timer
Does it have batteries?
Apr 05, 2008 | Heating & Cooling
Central heating programmer
is the buttons still working, eg, boost, on/off etc? or is the heating not working?
If so the LCD/Control panel may have lost power, this usually a switch/or fuse that may have been accidently powered of or blown
Feb 20, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
183 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
