Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117 Logo
Posted on Nov 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Miller syncrowave 250 tigrunner with gas flow
Miller syncrowave 250 tigrunner (serial # KJ ) with gas flow staying on.. but not always. already replaced the gas flow solenoid thinking this to be the problem... Any ideas?
  • 1 more comment
  • dave732 Nov 25, 2009
    UPDATE: Other than the Argon gas flow problem, the machine works fine otherwise. We are just going thru gas at a much faster rate then normal because of this. Thanks. DM
  • Greg Vance
    Greg Vance Jun 29, 2017
    Your problem is with the post flow board.
    And depending on the yr. They no longer carry it.
    Go buy a dayton 24 volt delay timer
  • shawn sheehan
    shawn sheehan Aug 07, 2017
    Greg Vance , do you have a diagram on how to wire in the dayton timer ??
Sean Wright
Level 3:
  • Master 2,045 Answers
  • Posted on Feb 02, 2010
Sean Wright
Master
Level 3:
Answers
2045
Questions
Helped
626574
Points
6368
Your problem is in one of two areas. The controller board inside the unit or a bad trigger on your gun.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
1helpful
Gas keeps running after you let off the foot pedal on synchrowave 250
Hi:
The normal set up on the 250 syncrowave will allow you to control your pre and post flow of gas. If the post flow is set up to more than 2 seconds that's the problem. If it is set on zero, then you have a leaky solenoid valve. Check your owners manual for troubleshooting anf repair.
I have a miller syncrowave 250 dx and my gas will not shut off when i let off the trigger even when my postflow is turned all the way to 0
Hi:
Probably your solenoid gas valve is obstructed by dirt. You can take it out and blow it with air or just replace it with a new one.
My Syncrowave 250 has no argon flow . Everything else works.
Remove the gas flow solenoid valve, bench test or have it tested and or replace. Follow the gas line to machine .This should be your gas solenoid If solenoid works fine, there must be a wire broken going it to itbut most likely tthe solenoid is bad.
I bought an older syncrowave 250 i dont know where the torch is connected and there it doest spark
Torch goes to ground side where gas will flow out of it. Use a tig torch 17 if water cooling is not needed or a size 20 for water cooled one.
I could not welding aluminium with Syncrowave 250DX. could you advise me on what's been missed ?
Gas, tungsten shaping,tungsten protrusion, Typeof gas grounding, gas pressure. setting on AC .
2answers
My miller dx250 keeps blowing a water line. what could be causing this?
if has good water flow, check that cooler coils are clean, make sure hot and cold connections are correct
Top Miller Welding Tools Experts
Sean Wright
Sean Wright
john h
Jay Finke
Jay Finke
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
