Question about Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
How can I get a manual for my Rheem Gas Furnace
How can I get a manual for my Rheem Imperial High Efficiency Furnace? Model #RGLE-10EQAGS?
Posted by bambiarn on
Anonymous
  • 244 Answers
Contact Paloma/Rheem customer (800-432-8373) support and tell them what you have; they'll send you the documentation - by regular/email.
Happy Holidays;]
JZ...
Posted on Nov 25, 2009
XG40T12HN38U0 rheem gas water heater manual
That is a residential power-damper water heater.
Rheem has use-and-care guides with parts list, but does not post service manuals.
http://waterheatertimer.org/pdf/Power-damper-troubleshoot-parts-manual.pdf
Following links will help with DIY repair.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://hometips.me/Mar/Whirlpool-flue-damper-manual.pdf
http://hometips.me/Mar/AO-Smith-high-efficiency-flue-damper-manual.pdf
Parts are ordered from Rheem
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 17, 2017 | Rheem Water Heaters
Rheem gas furnace displayes 3 blinks, does not ignite.....3 blinks means???
Look inside the unit, the codes are usually on or near the schematic of the unit. Otherwise check the owners manual.
Feb 16, 2015 | Rheem Water Heaters
I just had my furnace cleaned it is a gas rheem. The service guy said it was overheated because of a#3 tube he said the furnace heat exchange is black. What can be do regarding this
I presume you're talking about a gas furnace, even tho the title says Rheem gas water heater. Either way, it works the same for both.
Any black coloring on the heat exchanger is *not* from overheating. Black is from a sooty flame caused by a mis-adjusted burner. (In fact, a sooty flame is less hot). There is an adjustable "air intake plate" for air to enter the burner where the gas enters the burner. A proper flame is made by adjusting this air opening so the proper gas/air mixture feeds into the burner. If the air vent is closed too much it produces a sooty flame.
The age of the furnace is the most important aspect, and that helpful to determine a likely condition of the heat exchanger and burners. Other than a badly adjusted flame, the main thing to watch for is a badly rusted out heat exchanger. But black does not mean rust.
Oct 28, 2014 | Rheem 50 Gallon FVR NATGAS Water Heater...
How do I fix my a02 trouble code on my rheem ghe100-160a water heater
Commercial high efficiency gas
Rheem does not post service manuals or service bulletins for error a02, and installation manual does not show error codes
manual says to call for service
800-432-8373 in US
800-268-6966 Canada
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Gene
Sep 26, 2014 | Rheem ruud ghe100-160 water heater,100...
My control unit keeps alternating between 120 and IL. Cannot find code IL
Before calling service technican, copy following links for general troubleshoot resources and error codes, and manusls, and Rheem contact information:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Rheem-CondensingTankless-maintenance-2012.pdf
Error IL usually means delime the unit.
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
Read your product manual for yearly/monthly maintenance schedule.
Tankless are maintenance heavy and must be delimed each year.
Deliming using white vinegar take about 1 hour, and will not restore full efficiency to unit.
Tankless have the habit of forming lime deposits inside the heat exchanger, even with softened water.
Tankless cannot be exposed to more than 11 grains hardness in water.
Don't buy a tankless next time.
Read the manual first.
Aug 09, 2012 | Rheem Rtg53xn Natural Gas Tankless Water...
Install tankless hot water
Please contact your city permit office for construction requirements, they vary from city to city.
Jul 28, 2017 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Does the Rheem FURY Model 22V50F1 qualify for the energy tax credit?
1) Open following link to identify product.
http://www.rheem.com/product.aspx?id=CC643E03-4C15-4775-B139-E504A95651F7
2) Click information tab to see EF energy factor
Click specs and documents tab to download on-line manual.
Click Federal tax credit to read information
3) Tax info says: $300 for gas water heater with EF >= 0.82
EF energy factor for 22V50F1 is .58, so the answer is NO tax credit
4) Open following link to maintain efficiency of your gas water heater:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment with your experience so others can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 27, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem Tankless wh model rtg-74pvn shuts off error code c4 76
Contact Rheem; the Burner control unit has lost comm with the remote...the part is warranteed for up to five years.
Nov 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Loud blower on my new Rheem Power Vent 2 water heater
find out if it does the same noise with the venting disconnected
Nov 01, 2009 | Fasco Bradford White Hot Water Heater...
Rheem Paloma PTG-74PVN /  RTG-74PVN Natural Gas Indoor Logo
1,765 people viewed this question
Top Rheem Water Heaters Experts
Bill Johnson
jdthefixer
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
