Question about JVC KD-G421 CD Player
CD Player wont work and flashes 0000 A0
CD Player will accept disc, loads as normal but flashes 00000 A0 and wont play. When listening to radio the screen flashes 0000 A. Any idea what this is please?
Posted by batologist on
2 Related Answers
Anonymous
SOURCE: CD,s will not play
Mine works again!!! I removed the battery from the car, because I planned to change it. The KD-G421 worked all fine, after I connected the battery again. So I would say, that the problem, at least in my case, was resolved by removing the radio from the power supply and connecting to a +12V batterie again. Allow 1/2 hour of power supply removal. The root cause of the problem may be a voltage drop below 12V, which might delete some internal memory, although the radio receives and plays still music at lower voltage. After disconnection from the power supply, the radio starts up in the Demo mode again...
Hope this helps / Patrick
Posted on Jan 12, 2008
Anonymous
SOURCE: Error Codes
I've had a friend to stay who had this problem. I downloaded the user manual from the internet and the error code is not mentioned. I followed the procedure to reset the radio and this solved the problem.
Take the cover off the stereo and locate the small hole (towards the centre) which houses the reset switch. Insert something like a paper clip into the hole and hold for a few seconds. Then replace the cover and all should work. You'll loose all the radio presets.
Posted on Feb 17, 2009
2001 honda odyssey...my radio works fine, but the CD player wont accept any discs!
If its a 6 disk cd system the cd tray is wedge causing the cd option to not work. Most of the time one of the cd slipped out of its position causing it to wedge
May 19, 2015 | 2001 Honda Odyssey
I have a cd stuck in the radio & it won't eject it (states no cd), makes a clcking sound. how to fix it?
Usually there is a hole in close to the cd slot, where a pin can be inserted in order to push out a cd manually or a similar manual override.
Which CD player/ radio are you using?
Jul 01, 2017 | 2004 Chevrolet Avalanche
Cd carriage does not always load cd properly
Yes,as rightly suggested,dirts can cause the optical lens to reject some CDs.Use a a CD cleaner to clean the optical lens.If the problem persist,then you will need a qualified service personel to replace the lens.
Apr 07, 2014 | Bose Awrc1g Wave Radio Cd Player Only -...
Cd wont spin
The pladder motor is bad, "disc sits on top" most be replaced to regain normal operation.
Apr 14, 2012 | Sony CDP-CX300 CD Player
Sony boom cd/radio/cassette player says no disc and does not play even though the disc is spinning. The radio and cassette do work. We used a Dynex cd/dvd laser lens cleaner and it played for a short...
The laser diode is usually the first component to fail in optical disc players.
If you can, open the casing to expose the CD mechanism.
Point a cell-phone camera at the laser lens, which hides under a flat bridge.
Without a disc inserted, press play or eject / load the CD tray.
Via the camera, you should see the laser diode briefly flash as it tries to read data from where disc should be.
No flash means IR laser diode has probably burnt out.
Don't stare directly into laser beam for long periods with the ***** eye - rather use the camera as an interface.
The beam's visual color is red, but the CDS sensor of a digital camera sees the IR radiation as white on mobile's screen.
Dec 05, 2017 | Sony CD Radio Cassette Boombox, CFD-E90...
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
Cd player flashes ''error'' when you put a cd in. It waa playing fine. Just stopped playing ejected cd.
try another cd wont play if too scratched or dirty. handle disc by edge, dont touch the surface of disc no matter how lightly you hold it, you will leave contaminants that cloud the surface. if none ever work try them in a house cd player still no joy, then discs aare no good, if they work in home player then car cd died, time for new one. heck who uses cd any more? its a hassle to change them (only 16 songs!), hassle to replace lost daamaged or stolen(borrowed by friends), skip or scratches, get a radio with usb reader/player or SD card reader, can be had for under $60 , an 8gb SD card for $25 (4,000 songs<do you even KNOW the names of that many songs?) PLus, without a cd slot the thieves should leave your radio alone, thinking its just a normal am/fm radio. goto www.dealextreme.com for great deals and FREE SHIPPING.
Jun 21, 2010 | 2001 Chevrolet Silverado 1500
Error 12 and error 17 only for dvds
iiMesisage Cause Action
ERROR-11, 12, 17, 30
Dirty disc Clean disc.
ERROR-11, 12, 17, 30 Scratched disc Replace disc.
ERROR-10, 11, 12, 15, 17,
30, A0
Electrical or mechanical Turn the ignition ON and OFF, or switch
to a different source, then back to the CD
i hope this answers and solves your problems.
Feb 19, 2010 | Pioneer AVIC-D1 Car Video Player
Error Codes
Jan 09, 2009 | JVC KD-G322 CD Player
JVC KD-G421 CD Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
