KitchenAid K45SS Classic Stand Mixer Logo
Posted on Nov 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Transporting my stand mixer i laid it on its side in the trunk of my car. removing it later i noticed that there was oil dripping from it, it appeared to me that at least 1 tablespoon of oil had leaked from the appliance. it now sounds funny & i am afraid to use it. i could not find a place to add more oil. please help.
Custom Exchange
Level 3:
  • Master 397 Answers
  • Posted on Nov 25, 2009
Custom Exchange
Master
Level 3:
Answers
397
Questions
Helped
99687
Points
1012
One tablespoon shouldn't make that much of a difference unless unit is still leaking oil, their should be a notch on unit to refill
1helpful
My KA stand mixer fell over on its side during transportation - it was only on its side about 15 min. I see no oil leaks but it will not start. It is a KA Professional 5 Plus, approx 2 1/2 yr old
I don't think that model will ever have an oil leak, there is far less lubrication in the gears compared to the earlier models. You are going to have to remove the top cover & check all the connections for continuity. One of them may have come unplugged or be a bit loose. Remove the screw at the back holding the trim band on and then the 4 screws you can then see. Lift the cover off & check all the connections you can see. I vaguely remember there being a couple of wires plugged together towards the back that I once found to be the cause of no go.
Can I use lucas oil white lithium in my stand mixer
They do not use oil at all, they use food grade grease. Any oil that is dripping out is the liquids separating out from the solids in the grease. You either need to open it up and stir the grease u again or remove the old grease completely and repack it with new stuff.
Maitenance oil leek on head
Hiya,
I am sorry to hear you are having problems with your mixer. To stop the oil leaking from the front of the mixer, you just need to remove the drip ring and give it a good clean underneath and this should stop the oil from leaking out. Below I have added a link and if you watch on the timing "1.28" you will see how to remove the drip ring.
https://www.youtube.com/watch?v=n7813f_z6qM
I hope this helps!
K45SS leaks oil
Hiya,
I am sorry to hear you are having an issue with your machine! To solve this problem, you will need to remove the drip ring from your mixer and give it a good clean, this should stop the grease leaking.
I hope this helps you! :)
3helpful
Kitchenaid mixer leaking oil from head.how to fix it.
It's not oil, it's grease. Here is a very detailed article on how to add grease to the mixer. After you have added some new grease and tightened the screws it will stop leaking. The temporary fix is to simply remove the chrome ring as is done in the picture on the attached link, clean out the oil and stick it back on till it fills up again. It is called a drip ring for the reason that it catches the oil component of the grease which drips from the gasket when the screws loosen:
http://www.artisanbreadbaking.com/discussions/kitchen-aid.htm
10helpful
Leaking oil
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
4helpful
Adding oil to the k45ss
Hi. Goto www.kitchenaid.com enter your model # into the search window, look for the parts catalog for your mixer. Download this file. It will come in handy if you ever need to order parts, and will give you an overview of your mixer.
Goto www.mendingshed.com and locate the free Kitchenaid Service manual. This manual contains all of the info needed to service your mixer.
Finally, your mixer uses grease for lubrication. When you see oil dripping, it means that your mixer needs to be re-greased as the oil is separating from the grease base. I recommend Chevron FM ALC EP-2, this is a food grade grease that is non-toxic should you get some of it's oil in the mixing bowl at a later date. Remove the old oil and grease remnants from the mixer, including the planetary unit. You can remove the planetary by tapping the tapered pin out of the shaft. Clean and re-grease. After you've completed these tasks, run the mixer for a couple of minutes every week to keep the oil in suspension. This will extend the life of the grease.
Good luck! If this solution has assisted you, please rate it. ricardok45.
Oil leakage
Is the oil leaking down the beater shaft?Remove the silver drip cup,3 screw's one in the midlle,one on the right and one on the left.Once you drop the drip cup if it's filled with oil then you may need the seal's in the transmission replaced.
2answers
Moving a p660 mixer
I personally would not do it.
1helpful
Transmission oil
this unit uses grease if it is leaking out the grease has broken and needs replacing
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
