Welcome to FIxYa.com
the fuel door and trunk release should be in one panel on door.
Too there is a relay that may have gone bad.
Check relay and all fuses
Check fuse with test light
550604 tech # Jun. 5, 2006 2O1l907l Image Condition Customer States Rear Decklid. Hard to Close Customer states rear deck lid not closing properly. Technical Background Due to the stiffness of the original lock dampening rubber,
the rear deck lid may be Difficult hard to close. Production Solution A new lock dampening rubber was incorporated into production
during calendar week (CW) 4405. beginning ith VIN: IC_6M407025. Service Image Install improved lock dampening rubber Part No. lCO 827 589
B: Open rear deck lid. A Remove rear decked trim panel (see Repair Manual, Body
Interior, Group 70- Interior Remove Lock housing cover. Tip: To remove lock housing cover, gently pry between the locking
pawl and cover guides while pulling down on cover. Underside of cover shown for
case of location identification. A Remove the lock dampening rubber by pulling downward out
of lock housing. Image Install new rear lock dampening rubber Part No. lCO 827 589
B. Tip: Ensure proper engagement of lock dampening rubber retaining
tab into the lock housing and is seated on the guide slots. A Install lock housing cover. A Install rear deck lid trim panel (see Repair Manual, Body
Thank you for using FixYa.com
Regards, Lee Davidian
