I have just bought a Nokia E72 and want to pair it to my T305 I am being asked for a code I have put in 0000 but is has not been accepted does the T305 not support Nokia
First step:From your nokia e63,scroll to bluetooth goto paired device and click on add device after that,then pick up your bluetooth and press down the power button make sure you did not remove your hand from the button until it displays on your phone. Second step:After your phone has found the device,click on the device from your phone and you will be ask to type a password which the password is 0000.enjoy
step.1)try removing any unused bluetooth device name from your phone bluetooth menu. step 2) if the bluetooth memory is full even then you can not connect your bluetooth device. try now!!! enjoy!!!
By sony ericsson blue tooth i think you mentioned the headset. If you got the manuals for that headset, just check for the default pin code for the headset. But if not try these pin codes such as 1111 or 0000 or 1234 etc.
To Connect: 1. goto connectivity in ur mobile nokia e72. you will find it as a seperate icon in your menu, or you can get it from setting/connectivity. 2.in that switch blue tooth on. 3. now go to the next tab, and select options. from that select new paired device. 4. Now it will find the blue tooth headset. If it didnt detect, make sure your bluetooth headset is switched on. 5. then select that headset fro the search result and then it will ask for confirmation with the pic code. type the pin code you hv gt from the manual or try these(1111 or 0000 or 1234 etc.). then it will accept. If its accepted, the bluetooth headset will start working! Thanks, ask me if u gt any doubts.
What is a t305? It must be a device which can type a passcode. A passcode is a number that Bluetooth devices use to confirm that it is safe to connect. If you pair two mobile phones, it asks for a passcode. You enter it in one and then the same in the other.
If the t305 is not a device which can enter a passcode, then you need to refer to its manual to see what to do if the phone asks for a passcode.
Yes, I agree with joeypants77. Brilliant the passkey is 0000. I just bought a blackberry bold and it did not accept the Motorola T305 without a passkey and it workd:-)
If this solution doesn't work hold down both the volume up and down buttons on the head set for about 5 seconds whilst searching for a new paired device with your phone then when asked enter the code 0000 and connect
