SOURCE: adsl modem giving very slow and intermittent internet connection
this is not a problem with ur PC or router this could be in the Filter or splitter that ur ISP gave you, what i would do is call ur ISP and have them run a line test that could be the reason
i work for att. and that does happen ALOT you can also go to
www.speakeasy.net go to the bottom you should see whats my speed or test ur speed click on that and select a server closest to you and it will run a speed test up and download speed
good luck ,
July
SOURCE: just installed and fails to launch
I could not run this until I downloaded " d3drm dll " and installed it (I put it in the ' 3DHAD3 ' directory, or just put it in Windows directory). I forget where I found it, somewhere from Google.
SOURCE: Problem Event Name: APPCRASH Application Name: iexplore.exe
I think it is a usual problems, u can try to delete some bad application or spam or anything from : internet explorer - select tools - then internet option - in tab general, choose delete and then checklist all components there - and then OK
if it is doesn't works, you just have to enabled/uninstall your internet explore through program files or registry
hope works,
SOURCE: APPCRASH hpfcopy.exe
Reinstall rather fresh install the system for the better performance in future. and not to face the problem.
