Question about Dell PowerEdge 1800 Server
Power edge loght is red and blinking
My dell poweredge 1800 loght was blue but it is red and blinking now.
Posted by Amjad Attari on
Anonymous
    New Friend:
  • 23 Answers
You should be able to see the reasons in the front panel, remove the front cover and you will see a small display with some information passing slowly. Sometimes is just the redundant power-supply that is disconnected.
Posted on Nov 25, 2009
How to format Dell power edge 1800. please provide step by step procedure.
There is a difference between installation of workstation an server so you will need Dell installation CD for power Edge series of servers, you can download ISO image here from this link so download ISO image burn CD insert that CD on server and follow procedure.
Power Edhge Installation
Sep 11, 2013 | Dell PowerEdge 1800 Server
My dell poweredge 1800 doesnot boot, it gives an amber light after turning on . I have tried to remove the Ram but still the problem persists
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard.May also be caused by a defective card installed in the motherboard, i.e. video card.
Jan 31, 2012 | Dell PowerEdge 1800 Server
Dell Poweredge 1800 server not start, i press power button but nothing hapened
Your Model of Dell Poweredge 1800 server may not have a redundant power supply. The power supply is the most like cause of the problem. order a replacement power supply and replace the faulty unit.
Oct 17, 2011 | Dell PowerEdge 1800 Server
PowerEdge 1800 Server: I have a Dell power edge 1800 that was used as a s...
yes you can do that but you need the drivers for the scsi interface. when you install windows xp (for example) i think you may have to press the f6 key on the installation to add these drivers.
Otherwise, installation wont take place.
May 17, 2010 | Dell PowerEdge 1800 Server
Flshing Red Light on Dell Poweredge 1800 Server
I finally made contact with our IT dept who were abole to carry out a remote diagnostic test.
Problem has now been identified (problem with tape drive)
Jun 10, 2009 | Dell PowerEdge 1800 Server
High pitched noise red light blinking
A high pitch noise comes normally from blown capacitors from the motherboard or the power supply. But mostly high pitch noise comes from power supplies.
You could have to open up the power supply to see them.
Verify if it is the case and replace the faulty part.
May 26, 2009 | Dell PowerEdge 1800 Server
I was cleanning the power edge 1800 then when i
Check to make sure cables are firmly seated...sometimes when you're inside a box, you might jiggle a cable loose.
May 02, 2009 | Dell PowerEdge 1800 Server
Dell 1800 power edge is giving long beep continuously.
Power supply, system board, or keyboard problem
Apr 17, 2009 | Dell PowerEdge 1800 Server
Dell poweredge 1800 scsi drive not found
check if the drive is showing in the bios of the server,
shut down the server, take out the power cable, press and hold the power button so as to realease flea power, open the server, and reseat the data cable at both ends and if there is another power cable available in the server swap it with the existing cable plugged into the scsi drive.
and now try to start your server.
Further Queries are welcome
Feb 26, 2009 | Dell PowerEdge 1800 Server
Dell PowerEdge 1800 Server Logo
826 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
