Expert
- Posted on Nov 25, 2009
Re: My printer will not turn on. We had a storm
Solution one: Press and quickly release the Power button
Press and quickly release the Power button (
) to start a Power On/Off cycle. Do not hold down the button
Figure 1: Press and quickly release the Power button
If you press and hold the Power button too long, the product might turn
on My printer will not turn on. We had a storm - c01602202.gifwithout restarting. If this happens, press and quickly
) again.
If these steps resolved the issue
, you do not need to continue troubleshooting.
If the issue persists
, continue to the next solution.
Solution two: Check the electrical connections and outlet
Unplug the powerMy printer will not turn on. We had a storm - c00745315.gife electrical outleMy printer will not turn on. We had a storm - c00057913.jpger strip or surge suppressor.
Power module
Power cord
My printer will not turn on. We had a storm - c01733891.gif:
The power cord detaches from the power module. The term power supply
refers to both the power module and the power cord.
Carefully inspect the power cord for visible damage.
If the power cord or power module shows any damage, contact My printer will not turn on. We had a storm - c01733891.gif the power supply.
Disconnect the power supply from the back of the product.
Wait at least 30 seconds, and then plug the disconnected power supply
into an electrical outlet. Do not use a power strip or surge suppressorMy printer will not turn on. We had a storm - c01602202.gif/uploads/images/c01733891.gif" alt="c01733891.gif" class="h_mi" />
If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.
Reconnect the power module to the proMy printer will not turn on. We had a storm - c01602202.gifli class="h_mi">
) to turn the product on.
If the product still does not turn on, connect the product to an electrical outlet in another room, and then
quickly press and release the Power button (
) to turn on the product.
My printer will not turn on. We had a storm - c01896072.gifh_mi">
If the product turns on
, the electrical outlet in the origiMy printer will not turn on. We had a storm - c01602202.gifed the issue.
, continue with the next solution.
Solution three: Check the USB cable
- Disconnect the USB cable from the back of the product.
Figure 2: Disconnect the USB cable from the HP product
Press the Power button (
If the product turns My printer will not turn on. We had a storm - c01468528.jpgSB cable disconnected
, replace the USB cable.
Solution four: Check the batteryIf your HP product has a battery, follow these steps:
- Check the battery light. If the light is red, recharge the battery.
- If the battery light is still red after recharge, replace the battery.
Figure 3: Removing a battery (example only)
1 - Slide the battery release slider in the direction of the arrow
2 - Remove the battery
Instructions for recharging and replacing a battery are available on the HP Web site.
Solution five: Replace the power supplyIf
you have completed all of the troubleshooting steps and are still
experiencing a problem, contact HP to replace the power supply for your
product.
Solution six: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
